Question about Cyberhome CH-DVD 300 DVD Player
Where I can capacitors of circuit board, please help
Where I can buy capacitors of circuit board of Cyberhome CH-DVD 300 DVD Player as you said that use a 16 volt in place a 12 volt. Please help me. thank you for your time and attention.
    Genius:
  • Cyberhome Master
  • 1,550 Answers
The more important are the microfarads on the capacitor it can be 1000 mf,470mf you check the number in the body of the capacitor you can buy it in any radio shack.
Posted on Jun 22, 2008
My CyberHome CH-DVD 300 Player Not working CD, Only Disply "CyberHome DVD appear in Screen". I am in Near Tambaram. Please send Nearst Service centre Contact No. and Address.
Not reading anymore DVD movies disc or CD musics disc.The DVD laser eye head reader it is dead.Can't be repair must be replaced,not worth it well cost the same price as a new DVD player unit,if repair by a tech and have to buy parts for it.Basic DVD player unit are very cheap these day.U can buy a new one just a basic DVD player only will cost u like $40.
Aug 22, 2011 | Cyberhome CH-DVD 300 DVD Player
Tip
Cyberhome CH-DVD 300 Manual Have you lost your Cyberhome CH-DVD 300 DVD Player...
Have you lost your Cyberhome CH-DVD 300 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Cyberhome CH-DVD 300 DVD player is available here.
I hope that helps.
on Apr 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Tip
Cyberhome CH-DVD300 DVD Player
Symptom: Unit will not power up at all. Power indicator doesn't work.
or after inserting disk, screen says "loading disk" but then
says "bad disk".
Solution: This problem is usually caused by a bad 5Volt power supply.
Check the 5V output of the power supply board. The output
plug is clearly marked. If this 5V is less than 4V, the unit will
not operate. This is caused by defective filter capacitors in the
5V supply. These caps are easily identified. Replace these
two with the same values and the 5V should return to normal.
Note: Because of the confined spaces on the board, only use caps
that are of the same physical size. Capacitors are made in a
varity of hights and diameters with the same electrical
specifications. Do not try to pigtail a larger cap in circuit. The
circuit will not work correctly. I can supply these if you can not
find them locally.
on Mar 28, 2010 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Jun 08, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD WILL NOT PLAY
i have repaired a couple of these cyberhome dvd players-if you are getting a no disc,it is because of a defective disc table motor or bad flex connector(between lens & circuit board).if your unit is not powering up, you should check the power supply board in the unit(.there are capacitors that go bad) i recomend these checks be made by a tech. rkelecworks.
May 12, 2008 | Cyberhome CH-DVD 300 DVD Player
RGN ERROR
I found A great website on only Cyberhome DVD problems and answers hope this helps. http://forum.cyberhome-help.de/viewforum.php?f=4&sid=a36c52c7bf9d531a54b649a1dcf1f02e
Oct 08, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
121 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
