Question about HP Computers & Internet
Laptop Cleaning/Repair My roomate spilled a drink on my keyboard last night and now a few keys don't work. Is there something I can try to clean it on my own before I spend a whole lot of money to have it cleaned or repaired professionally? Or should I just take it in to have it fixed?
  • driven2187 Jun 09, 2008
    Could you give me a rough idea of how much getting the keyboard will cost me? Thanks.
  • 458 Answers
That is something that you should not attempt .. Because most likely you will need to replace the keyboard...
If they are just not working because they are Sticking or Stuck, you can repair this by yourself....you can remove the keyboard and clean it, also checking the ribbon cable that goes from the keyboard to the motherboard... look for any burn spots near the keyboard plug connection, chances are that just simply replacing the keyboard would fix it ..
You also will need the entire laptop taken apart to see if the "drink" spilled onto other parts, or worse... the motherboard...
Posted on Jun 09, 2008
Have a Gateway M285e laptop that the letter 'e' on the keyboard doesn't function. Will cleaning the keyboard resolve this issue? Thanks
It is possible that there is something sticky keeping the "e" key form working. Removing the key and cleaning around it carefully with alcohol or alcohol water 50/50 or 100% mix might free it up. Use Que-tips or something like that. try to clean around it first. If that does not work try gently lifting up on the key with a small screw driver or knife. You may hear a small pop. this could go either way for you good or bad, so be car full. then try cleaning around the spot ware the key was, gently replace the key.
You may also consider plugging in a cheep $10.00 key board and see if this works. I spilled a large drink in min and needed to use an auxiliary key board until I replaced the computer.
Apr 12, 2015 | Gateway Computers & Internet
The t and the y don't work
cleaned them with what?
key don't work on a laptop due to something being spilled on them(liquid) or something underneath them(hair, crumbs etc)
hold the laptop upside down(off of course) and GENTLY tap the edge near the keyboard bottom on table you might find something dropping out
otherwise new keyboard time
May 25, 2012 | MSI CR630228US 156Inch Laptop Black
Sticking keyboard keys grrrrr no drink or anything
Get a can of compressed air and see if blowing on the keyboard will help. If not then Try a keyboard cleaning kit:
Compressed air:
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&biw=1920&bih=904&tbm=shop&q=compressed+air&aq=f&aqi=g10&aql=&oq=
Cleaning kit:
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla:en-US:official&q=keyboard%20cleaner&um=1&ie=UTF-8&tbo=u&tbs=shop:1&source=og&sa=N&tab=wf&biw=1920&bih=904
May 10, 2011 | Acer Computers & Internet
I had a drink spill on my keyboard last night. I instantly worked on cleaning it up and did a very good job except for the 1 key in the upper left. It is the only key that is having a problem. Is there a...
You will have to remove the keypad to get access to the pad below. It is possible that there is some liquid logging below, so use a hair dryer to softly warm out the liquid.
Repeat this for sometime, use a good air jet along , if not the keypad can be opened and the pads wiped out dry.
Oct 11, 2010 | Acer NSK8458AN Keyboard
Spilled water on keyboard. a few keys don't work
If this problem occurred recently you might still be able to save the keyboard. However, it is a painstaking method of popping out each of the keys that are not working and cleaning them off (preferably with some contact cleaner) and making sure that there is no corrosion trying to form due to the moisture. Be careful when prying up some keys as some keyboards (especially laptop keyboards) are hard to put back if you don't have the right tools or the know how. I suggest looking up keyboard removal techniques based on the brand of your keyboard/laptop.
Good luck...
Apr 17, 2010 | Computers & Internet
Keyboard suddenly got weird
A keyboard is nothing more than a collection of small switches under the keys. A liquid will short out between the contacts of the switches and is the same as hitting the key. There are still fluids inside they keyboard circuitry. By using it like this it can short out the keyboard and ruin it. It needs to be taken out and cleaned and dried throughly before it is ruined. (might already be ruined). You can usually find replacement keyboards on places like ebay.com
Oct 01, 2009 | Computers & Internet
Laptop keyboard not operational
If you replaced the keyboard with a Dell replacement 1501 keyboard and it still doesn’t work then yes the motherboard will probably have to be replaced. If your son spilled water on the laptop it could clear up after it completely dries. If it was juice, soft drink or sport drink the laptop could develop other issues. The syrup in these kinds of drinks don’t evaporate, they just remain there and accumulate foreign particles like dust, hair, dirt and eventually start to corrode electrical contacts like acid. Similar to the terminal posts on a car battery.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Apr 28, 2009 | Dell Inspiron 1501 Notebook
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Jul 21, 2008 | Dell Inspiron E1505 Notebook
How to remove keypad gateway mx3701 for cleaning
your best bet is to buy a new keyboard they are inexpensive and it is not worth it to try and repair it. it's not really a good idea to drink anything around any electronic devices !!!
May 10, 2008 | Computers & Internet
Computers & Internet Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
