Question about Microsoft Xbox Console
X box I recently got an xbox original for free and it had a orange and green flashing light were it should only be green help plz thank
I just encountered this probmlem too. the problem is that your cable that connects your xbox to the tv is not plugged in or might not be all the way in
Posted on Dec 07, 2008
    Problem Solver:
  • 15 Answers
Hard drive is broken u have to get it checked out by a tecnition
Posted on Jun 10, 2008
I have an xbox the first one black with x on top it has just started to come up on the screen in a box saying your xbox need service can you help thanks
In the top left or right corner there will a number, eg 07, which means its a hard drive error which means the xbox is more or less stuffed as each hard drive for the original xbox is specific to the main printed circuit board.
Theres another symtom that tech's call FRAG lights. Where the lights Flash Red And Green, hence the acronym FRAG, if you are getting this symptom, theres a chance your xbox has died.
I hope this helps. Good luck.
Sep 06, 2010 | Video Game Consoles & Games
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
My xbox 360 want turn on HELP ME PLZ
by orange light do you mean 3 red flashing lights on the front? if so you have the red ring of death which is unfixable by someone with no experience, and they should replace that for free as it is a hardware crash which is there fault all the first xbox 360s got it at some stage
Jun 24, 2009 | Microsoft Xbox 360 Console
My xbox 360 won't turn on!!!
When it says ORANGE on the Power box, that means that the Power box is waiting for the console to be connected, You might wanna try another power box if you have a friend or relative nearby, and if another power box does the same thing, then you can call xbox support to check the warranty of your xbox 360, then send it in for repairs
FYI:
The light on the power supply should be GREEN in order for the console to turn on
Mar 15, 2009 | Microsoft Xbox Console
I think the X-box does not Sync
Try this method :
Check if your XBOX 360's Power Supply has an orange or green light. If it is RED, then unplug the power supply from the socket.
If it is orange or green, then try and unplug the Power Supply from the Back of your XBOX, wait 1 minute. Then plug it back in.
If that doesn't work then call 1-800-4MY-XBOX and speak to a XBOX Representative.
Jan 04, 2009 | Microsoft Xbox 360 Console
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
3 red lights on my xbox 360 please help
Hey cozierterry,
While this may be an indicator that something is wrong with your Xbox 360, there are a couple of things that you may want to consider before seeking additional assistance.
According to information provided by the manufacturer, the light on your Xbox 360's power supply should still light up green even when the console has encountered a three red light problem. If the light on the power supply isn't green, you will want to take different actions based on what color is displayed. If this light is red, the AC adaptor may either be defective or has recently overheated. If the light is orange, you may need to double-check all cable connections are secure. If the light on the AC adaptor isn't lit, the AC adaptor may need to be replaced.
Alternatively, you may want to try turning the Xbox 360 off, then pressing the power button again roughly 10-15 seconds later. If the unit powers on normally and the three red lights disappear, the system may simply have needed to be reset.
Should the problem persist however, you may need to speak directly with Microsoft for further assistance, as three red lights often indicate a hardware failure that requires repairs. You can reach Microsoft's toll-free Xbox support hotline at 800-4MY-XBOX (800-469-9269), or you can always request service through the Xbox website:
http://www.xbox.com/en-US/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 28, 2008 | Microsoft Xbox 360 Console
X box has red rings
Hey thepaper1,
While this may be an indicator that something is wrong with your XBox 360, there are a couple of things that you may want to consider before seeking additional assistance.
According to information provided by the manufacturer, the light on your XBox 360's power supply should still light up green even when the console has encountered a three red light problem. If the light on the power supply isn't green, you will want to take different actions based on what color is displayed. If this light is red, the AC adaptor may either be defective or has recently overheated. If the light is orange, you may need to double-check all cable connections are secure. If the light on the AC adaptor isn't lit, the AC adaptor may need to be replaced.
Alternatively, you may want to try turning the XBox 360 off, then pressing the power button again roughly 10-15 seconds later. If the unit powers on normally and the three red lights disappear, the system may simply have needed to be reset.
Should the problem still persist, you may need to speak directly with Microsoft for further assistance. You can reach Microsoft's toll-free XBox support hotline at 800-4MY-XBOX (800-469-9269), or you can always request service through the XBox website:
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 25, 2008 | Video Game Consoles & Games
Microsoft Xbox Console Logo
37 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
