Creative zen 30g will not turn on. when you try it goes to rebuilding then freezes and the says firmware problem. you cant do anything after that. i trie the reset button, same thing. tried charging and uncharging, same thing.
  • Tiffany Strickland Nov 25, 2008
    I charged mine this morning and now it won't power up either. Tried reset button and also tried to re-charge. I can't find the mp3 player on the usb hub when I plug it up to computer to charge. It''s not locating it!!!
    help please!!
  • Anonymous Apr 27, 2009
    Ye, I have the same problem, is it knackered????
1 Answer has firmware that can be downloaded to the PC then installed to the Zen VIA USB. The drive inside the player may need replacing though, it is just a standard IDE laptop drive.
I would try the firmware first then try replacing the drive if you have access to a spare one.
Posted on Aug 07, 2008
My Zen M 30g keeps rebuilding....tried to reset but it won't work...I put the pin in the reset hole and it won't do anything til I pull the pin out then it comes on but is rebuilding???? Help please!!!
Welcome to Fixya's Community.
Your Mp3 Player is Having Problem with the Firmware(Corrupted) Now you need to Upgrade it Firmware, in order to solve this problem Please follow these Steps:
  • To install this firmware
    1. Download the file into your local hard disk.( check out the link below)
    2. Close all application windows that are currently running on your computer.
    3. Connect your player to your computer.
    4. Double-click the downloaded file and follow the instructions on the screen.
  • When your player restarts after installing this firmware, the following will occur for the first time only:
    • The Rebuilding Library screen will appear.
    • Photos may take slightly longer than normal to appear.
  • This firmware supports the playback of Audible Type 2 and 4 tracks.
  • Important: to transfer Audible content, you must have AudibleManager version 5 or later installed. AudibleManager allows you to download, burn, organize, transfer and listen to Audible audio content.
The Firmware updater.
Additional Help:
Creative Zen M 30Gb Manual Guide.
Thank you for Using Fixya.
Please let me Know if you need any further Info.
Good Luck.
Nov 09, 2009 | Creative Labs ZEN Vision:M Digital Media...
I have a creative Zen 2GB & when I turn it on it has to rebuild libraies and then once that is complete it freezes on the one song & I cant turn it on or off
Ok just fixed mine by pushing pin into reset hole. Hold play button turn zen v back on format player. yes you will lose your data but its better than buying a new mp3 player. download zen firmware update plug player in and update. This problem is caused by a corrupted file so the only way to fix it is full formate.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Turns on and then goes to rebuilding screen then says firmware problem but computer doesnt register that its hooked up
check on the zen site and make sure you have the current version for your zen.
download it and do a rebuild with new firmware.
this mp3 has a hard drive, the exact one that the ipod has. They are not immuned from crashing for sure.
But doing a reinstall of the software will probably help alot.
May 19, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creatve Zen freezing at rebuilding
Try using a different computer or a different USB cable. It is possible that the Windows mass storage driver is having issues. You may also want to try to download the newest software from Creative and install that. You may also want to try to plug it in and then press the reset button and see if it detects it when it restarts.
Also try putting an SD card into the expansion slot and see if it detects it as as mass storage device.
If none of the above work and it is still under warranty (less than 90 days) I would send it to Creative for repair or replacement. If it is out of warranty, Creative's repair costs may not make it worth fixing. When my out of warranty player needed fixed they were going to charge 125 USD and I only paid 200 USD for it about a year earlier. When it finally got to be too hard to deal with I opted for an iPod. Granted they are more expensive but the support is better and the warranty is 1 year.
Cheers and best wishes.
Jan 01, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
What verson of Windows Media player have you got on your pc?
Find one with version 9 install the creative software and then try the reload of the firmware .Zen has problems with windows medai player 10 - 11.
Jul 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen vision m firmware problem
Lotsa people are having the same problem with the firmware updates. Go check for your warranty, the product was working fine before applying THEIR firmware update.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 28, 2008 | Creative Labs Zen Vision Digital Media...
Zen Xtra 40 GB
and download the firmware for you version,.
Dec 26, 2007 | Creative Labs Zen V MP3 Player
174 people viewed this question
