Question about Hotpoint Kitchen Ranges
Kitchen gas range
My oven heats up to the right temperature, but then continues to heat, and the food burns
  • 868 Answers
Replace the thermostat control. PLEASE RATE THIS!
Posted on Jun 09, 2008
My apartment has a small Magic Chef gas kitchen range, I don't know the model number but on the back top of the unit is a space that heat pours out of when I use the oven. is this supposed to happen?, is...
Yes,this is normal.
The heat must escape all ovens for them to function correctly.
The advantage is, you can place a pot or pan of food near the vent to stay warm while the baking continues.
Works good as a bread warmer wrapped in foil also.
Aug 23, 2010 | Magic Chef 31000 Gas Kitchen Range
Uneven cooking food has to be turned every 10 minutes, bottom of food burns and top dosent cook
How does the food know which way its facing?
Try covering the food with a lid from a smaller pan.
And always remember...to cook faster, sometimes you have to cook slower! A carbon layer on food acts as a heat shield against further cooking!
Dec 09, 2009 | Baumatic BT2395SS Gas Kitchen Range
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Tempature does not heat properly
Replace the oven temperature sensor.
Oct 27, 2009 | Tappan TGF320 Gas Kitchen Range
KGST307 gas stove has a temperature control problem.
the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
Oven doesn't heat up properly
ovens can be calibrate for the right temperature. the adjustment screw is locate inside the shaft of the thermostat. when you remove the oven knob.
Nov 15, 2008 | Whirlpool GS460 Gas Kitchen Range
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Thermador oven
If oven does not heat check heating element and oven control. Follow also suggestion below:
" It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
From repairclinic
Aug 17, 2008 | Thermador PGR366 Gas Kitchen Range
Parkinson cowan sonata 55x gas cooker
When foods come out burned, soggy, or unevenly baked, it generally means heat isn't being distributed evenly throughout the oven, it's escaping out the door, or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven.
2) Check the door gasket, and, if necessary, replace it.
3) Be sure nothing is obstructing the vent.
4) Reposition the oven racks so baking pans aren't too close to the heat sources.
5) Check your baking pans. If they're dark, they may be burning your food. Reduce the temperature by 25 degrees Fahrenheit when baking in dark metal or glass pans.
You can also recalibrate the controls. If your oven has calibration right on the knob, you can calibrate the appliance as follows. If it doesn't, call an appliance repairperson. To adjust the thermostat's calibration:
1) Remove the oven temperature knob by pulling it off its shaft.
2) Notice the current setting, and then move the pointer in either direction to adjust its temperature slightly up or down. It's intentionally difficult to move the pointer on some models; if this is the case, you'll have to remove a couple of screws. Figure that moving it one notch will change the setting by 10 degrees Fahrenheit.
3) For more accurate calibration, call an appliance repairperson.
Do rate the solution i need it!!
Jun 17, 2008 | Parkinson Cowan SG340 Gas Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Justin Duby
Justin Duby
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
