Question about Frigidaire FWS833A Top Load Washer
As washer spin-dries, makes objectionable noise, and timer switch spins at the same time
As above
  • 868 Answers
If you tilt back the washer you can look under it and see if your belt is ok.Also spin the pulleys by hand 1 at a time and see if you can isolate the sound. Please Rate this solution !
Posted on Jun 09, 2008
I have an older-model GE washing machine. About 2 weeks ago I went down to put clothes in the dryer & the washing machine was still full of water but the dial was in the "off" position. I...
Sounds like your timer is going out. Turn it to the spin cycle and see if it'll spin. If not jiggle the timer handle and see if that does it. If it works after jiggling the handle then you need a new timer which can be expensive. Or on the cheaper side it could also be a lid switch but sound more like a timer. Check the lid switch also.
Dec 28, 2010 | Washing Machines
Kenmore washer not draining,spin drying
if you can hear the motor running with a loud ticking noise you probably need a drive coupler. if it stops dead and nothing happens you probably need a lid switch.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Waher will not go into spin cycle. It makes a buzzing noise and will not spin.
it's most likely your timer....u can get the machine to spin out your clothes by pushing the timer in and pulling it back out. this resets the motor and makes it turn backwards. it's a pain to do this because you have to keep an eye on the time. this will get you through until you change the timer.
May 28, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
sounds like you have a broken lid switch on the washer, maybe someone slammed the door or placed or stood on top of the washer, a broken lid switch won't allow washer to go into spin mode is a safety device so if is on spin cycle an someone sticks their hand it the machine stops an not breaks your hand.
broken lid swtich
good luck leave some feedback thanks!
May 28, 2009 | GE Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAX4232KQ0 maker loud noise at spin cycle and then stops
There are a few things that can go wrong, If the washer doesn't adgitate or spin then probably the coupler is broken, lean the washer back and look under the machine between the motor and transmission you will find the coupler. (very common)
Coupler Part# 285753A $22.95
If its agitating but not spinning, check the lid switch, (easy check just listen for the click when you shut the lid, Or you can bypass it with a jumper wire under the console there are only 2 screw that hold the console down they are philips and either located in the front lower corners or the back lower corners)
Lid switch Part# 3949247 $42.95
If lid switch is good and the motor still doesnt run you might have a bad timer (RARE)
Timer Part# 3954563 $95.95
If you can hear the motor running but its not spinning and you have rulled out the coupler then your probably looking at a clutch (common problem) either the clutch isnt grabbing or the brake isnt releasing both problems solved with the clutch kit
Clutch kit Part# 285785 $44.95
Worst case your looking at a transmission, (uncommon) to rule out, make sure its agitating, then put washer in spin cycle. look under the washer to see if the clutch bell is spinning. if its not then you will need a transmission.
Trans Part# 3360629 $172.95
if its making loud noises when it stops spinnig then the block is bad.
Block Part# 389140 $14.95
Feb 07, 2009 | Roper RAX4232KQ Top Load Washer
Washer won't spin clothes dry enough
Dear Langley,
please do the following checks.
This may be a spin problem or a drain problem
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
please rate this solution.Thank You Langley
Dec 16, 2008 | Kenmore 15944 Top Load Washer
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
