Question about Belkin (F5D72304F5D7000) Router
Belkin hi what is the ip to belkin router thanks
  • wolfgangva Jun 09, 2008
    ip to belkin thanks
  • 3 Answers
192.168.2.1
Posted on Jul 07, 2008
What Is the Default IP Address of Belkin Router? And determine Admin password?
HI ! HERE YOU GO!
https://www.lifewire.com/what-is-the-default-ip-address-of-a-belkin-router-818062
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
How can I get my IP address set for my Belkin router... IP # 192.168.2.1 ???
Hi go to http://whatismyipaddress.com as soon as the page loads you will see your ip address and if you need other ip details just click the gray box beside the ip address it will be labeled additional ip details you will see things you didn't expect!! hope this helps
Feb 02, 2011 | Belkin Basic Wireless Router
Hi, I have a Belkin N wirless router. It's in a very large house and I want to add a couple of range extenders onto it and wondered if I have to set IP's or similar within the router? I will be adding...
hi no need to set ip it will automatically set them as there not wireless and no need for password either, just plug them in and everything will sort itself...hope this helps
Dec 09, 2010 | Belkin Computers & Internet
IP conflicts using the Belkin Model 570230-4 router and I do not have the belkin utility CD.
For that you need to enable dhcp on router.
Then set in your computer network adapter property to ip get automatic.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then enable dhcp and save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 07, 2010 | Belkin Computers & Internet
Unable to get the managment page on belkin wirless g plus mimo router. before it was working on the ip address 172.16.18.xxx but now its not openning managment page at all, can i see someanother way what...
or
http://192.168.2.1
Feb 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin N router and linksys ip cam
You need to connect the camera directly to your computer and have it manually assign an IP Address on your computer so you could access the camera on the first hand.After that you need to range the IP Address of the camera accordingly to the IP Address of your network.
May 05, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Wireless modem router
Where are you actually putting your ip and dns numbers? I need to check if your actually
connected to your belkin router, so on your computer we need to launch your command prompt
if your using windows. Can you brief me on what system your using there?
thanks
Sep 26, 2008 | Belkin (F5D7231UK4) Wireless Router
Hi can i ask?
Normally the default IP of the Belkin router series is 192.168.2.1 but to find out what is on your Belkin it would be easier to connect your computer to it via wired or wireless then.
Click start then run then type in CMD then hit ok
In the Command Window type in IPCONFIG
the IP address isthe IP of your computer
The gateway is the IP of your router.
If you need further help just respond back
Sep 03, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
Feb 03, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D72304F5D7000) Router Logo
646 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
