Question about SanDisk Sansa Clip MP3 Player
Update time need to update time or clock, need instructions
  • 8,596 Answers
What timer? what clock? This one doesn't have a clock or a timer. There are backlight timer and powersave features that operate in 5, 10, 15, 20 min increments, etc. but there is no clock.
Here is the complete user's manual for full details:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
Posted on Jun 13, 2008
Change clock on Pontiac g6
There is 2 different radios. With or without rds. Here are the instructions for both.
Setting the Time for Radios with Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the clock button to enter the clock set mode, then press and hold the clock button for three seconds until UPDATED displays. If the time is not available from the station, NO UPDATE displays.
RDS time is broadcast once a minute. After tuning to an RDS broadcast station, it can take a few minutes for the time to update.
Setting the Time for Radios without Radio Data Systems (RDS) To set the hour, press the clock button. The clock symbol displays and the hour flashes. Turn the ADJ (adjust) knob to increase or to decrease the hours. To set the minutes, press the clock button again. The minutes flash. Turn the ADJ knob to increase or to decrease the minutes. The time can be set with the ignition on or off.
Mar 08, 2015 | Pontiac G6 Cars & Trucks
Need instructions for model CKS2022
Emerson does not list a CKS2022 model. Other Smartset manuals are available here: http://www.emersonradio.com/owners/SmartSet%20Series/ . The instructions for a similar model like the CKS2021, http://www.emersonradio.com/owners/SmartSet%20Series/CKS2021_ib062603.pdf , or the CKS2023, http://www.emersonradio.com/owners/SmartSet%20Series/CKS2023_020504.pdf . may be the same as those for the 2022.
BTW: you can find the directions to update your Smartset for the modified Daylight Savings Time here: http://www.emersonradio.com/dst.htm .
I hope this helps.
Mar 06, 2011 | Emerson Smartset Clock Radio
How do i change the time?
Hello, here is the instructions for setting the clock
RDS Clock Time Broadcasters can choose to send clock time information in the RDS data. This information can be used to update the clock time on the radio. RDS clock time is broadcasted once a minute. To set the clock using RDS clock data perform the following:
• Press and hold the HR and MIN buttons together for two or more seconds to update the time.
• The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
if this doesnt work, just simply push and hold the hr and minute buttons to set the time
• Press and hold the HR and MIN buttons together for two or more seconds to update the time. • The display will show "UPDATED" after receiving the broadcasted time data. • If the broadcaster is not broadcasting the time data, the radio will display "NO UPDATE" and the time remains unchanged.
Oct 23, 2010 | 2002 Chevrolet Impala
Radio controlled clock model 6302000 - cannot
I have the same clock and had the same problem. My clock was a demo and had no instructions with it. Here is the solution:
1. Pull out the battery and wait 10 seconds then replace the battery. The satellite symbol should start flashing after a few seconds.
2. Put the clock outside or in a window sill till it updates. This could take a couple of minutes.
3. Press the Mode button once to enter programming mode.
4. Press the Adjust button as many times as needed to toggle through the time zones.
5. Press the Mode button once to exit programming mode.
Apr 02, 2010 | NexxTech Travel Alarm Clock (63-8042)
Sony vaio vgn-fs775p laptop real time clock not keeping time
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
Mar 09, 2010 | Sony VAIO VGN-FS790 Notebook
Need to update daylight savings time date
This is from the Timex FAQs site:
Q: My clock did not update for DST.
A: We apologize but there is no patch available. Consumers must change clocks manually. Due to newly enacted government regulations, effective this year you must change the time manually, since the calendar was programmed to change according to the time DST issued by the government, it will not recognize the change after 2007. Now the time must be changed 4 times. Press & hold the time set button until the time flash, then release it and press the ff >> or << rev buttons.
Oct 26, 2009 | Timex T311T Clock Radio
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Apr 02, 2009 | Hardware & Accessories
Instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
Nov 03, 2008 | SkyScan 86709 Atomic Wall Clock
Clock will not adjust properly
Inside the PC is a small lithium cell battery that may be going bad. Or, check for updates on microsoft update to get the clock settings where they need to be. Also check in your settings that you are set to the correct time zone.
Apr 07, 2008 | HP Compaq Presario S3040SE (DF222AR#ABA)...
SanDisk Sansa Clip MP3 Player Logo
88 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
