I have a Pelonis Model MWF1-12CR AIR CONDITONER 1200 BTUs
Everything works but can't get any cold air
  • 263 Answers
SOURCE: Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Posted on Dec 31, 2007
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Posted on Mar 16, 2008
SOURCE: maytag air conditoner
lilliyan77@yahoo.com,i am work in aircondioner (a\c tec)
Posted on Aug 07, 2008
dealt_soul
  • 296 Answers
SOURCE: blows only cold air
Check connection to heating elements. My have bad heating elements
Posted on Jan 19, 2009
SOURCE: Everything is working .No cold air coming from vents
if the compressor is on the condenser fan ison the evaporator fan is on and no cool means lack of freon and also you can start and check with gauges
Posted on May 04, 2009
My air conditoner blows cold for maybe 15 minutes than warm
Are you using a "very powerful" AC to cool off a relatively small space? The AC has a thermostat, if the return air is meeting set point, the compressor would stop. The fan could still be circulating, hence the perception of warm air. What you should do is don't block the ventilation, and direct the cold air toward the ceiling. The cold air will sink (due to higher density) and create better circulation and temperature mixing.
Jul 19, 2011 | Whirlpool Heating & Cooling
Im just trying to find out how many btus my air conditioner is
It says it in the model number 12000 btus or one ton enough to cool 700 to maybe a thousand feet.
Jul 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
PORTABLE AIR CONDITONER MODEL#APEOIAJMI-DOES NOT
If you turned this unit on right away after you received it you may haved damaged the compressor. You should always let a rfrigeration or a/c unit sit in its up right position for atleast 12 hrs. before operating, so that pressures and oil can equalize inside the system, unplug the unit and check the wires at the compressor and make sure they are still connected, Good luck.
Mar 05, 2010 | Heating & Cooling
What is tht tonage if i have a model#wpka 031jaz weatherking air conditioner
2 1/2 T the 31 in the model # is 31,ooo btus divide by 12,000 btus in a ton
Aug 06, 2009 | Weather King 10AJA3601AH Air Conditioner
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Need exhaust hose for Pelonis MCP-08ER
you can make some thing work dryer vent and duct tape cheap fix good luck Tom
Jun 27, 2009 | Pelonis KCD-25YI Air Conditioner
Air conditoner quit blowing cold air while driving home
you can try recharging the system...it's a fairly simple process and freon can be purchased at any parts store. here is an overview:
http://www.aa1car.com/library/ac_recharging.htm
Jun 24, 2009 | 2004 Ford F150
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
Nov 24, 2008 | Dometic Rooftop RV Air Conditioner
Dec 31, 2007 | Heating & Cooling
Heating & Cooling Logo
154 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
