Question about Dishwashers
Hi there,we are getting error code 004 coming up on our dishwasher, make is Heller, model is HDWE 12, as we don't have a manual,thanks
  • 1 more comment
  • Anonymous Jun 24, 2008
    We have the same problem with a DWH3 Model. We do not have a manual either as it came with the house.
  • helecolm Jul 28, 2008
    DWH3 - error 02 - NO MANUAL any ideas ?? goes part way into cycle, does not open the detergent dispenser and then goes into error 02
  • Anonymous Sep 23, 2008
    Hello - I have the exact same model and the same problem - the cycle runs then I get an error 04
I have the HDWE12/SS manual, the following may help, or not!
According to my manual error 4 means it is "overfilled", and the possible cause is "too much inlet water". I doubt that is much help but that's all the manual says.
Error 2 is "longer draining time" with a possible cause of "the installation position of the drain pipe is too high"
Posted on Feb 09, 2009
There is a small switch on a polystyrene float in between the bottom of the dish washing cabinet and the bottom floor.. its purpose is to switch off the appliance in the event of water leaking down into the electrical area... if this switch is lifted error 4 occurs within seconds, .... to clear, drain water, power down for 30seconds, power back up... in my case the fitting that takes water to the top rack was broken and the water leaked down the inside of the washer and flooded the bottom... i found the best thing to do was to remove the left side cover for inspection. thats how i discovered the facts listed above.. please don't ask for more advice as this is ALL i know..
Posted on May 10, 2010
Heller MIST40B instruction manual
I am assuming this is not a dishwasher but a mist fan.
Try contacting awa in Australia who support Heller brand products.
Ph:
1300 366 144
email:
warrantysupport@awa.com.au
Jan 05, 2013 | Dishwashers
Dishwasher error code
The manual shows there are 3 possible causes of the alarm
1. water supply is not there
2. drain time is too high - possibly a blockage in the kitchen sink drain
3. the water overfill in the base.
Most likely the cause could be 2 or 3. If kitchen drain is clear then the reason could be a faulty overfill switch at base of dishwasher assuming there is no water collected at the base where the motor and pumps are located.
Jan 04, 2013 | Dishwashers
Hi , I dont have a manual for my ilve intergrated dishwasher but on the display panel its showing E3 cam you tell me what this means. thanks Michael
ILVE modle number WQP12-9319A on the manual it is No 6 which says delatstart time to display booking time or water temperature and when the E3 comes up you
cannot start
Jul 11, 2011 | Dishwashers
Beaumark bm-dw9702-ss dishwasher error code 004??
I had a error 004 on a Beaumark Model: BM-DW9702-WH Dishwasher which caused it not to run. The Manual stated it was To MUCH INLET WATER. I replaced the Inlet Valve with Part#: DW-53. The Dishwasher now runs great!
Oct 28, 2010 | Dishwashers
Baumatic WQP12-9213 - Error Code 004?
hello
The "004" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while 004 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the 004 error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
Jun 03, 2010 | Washing Machines
Heller dishwasher error 004
Hi all, this error (004) means that there is an overflow....To solve it do this:
1) Disconnect the power to the dishwasher
2) Remove the left cover (to do it remove all the screws..2 are located under the top and 3 behind the front lower cover)
3) Dry very well the bottom plates where is the motor and the electrics wires.
4) The overflow switch is a floating contact, so check that there is no water under it. (You can check it pushing gently the contact).
Before reinstall the cover check that the dishwasher is working fine!
IF YES.....WELL DONE MATE YOU SAVED YOUR MONEY!
Cheers....Aldo
Sep 20, 2009 | Dishwashers
Error Code: 004
shut off power to the unit first or unplug it after 1 min turn back on this may solve the problem
Aug 19, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Heller DWH16 slimline dishwasher not filling with water properly has to keep being moved to try and get it to fill which sometimes succeeds bit not all the time
I have a heller dwh16 dishwasher - it appears to be in perfect working order but does not heat up with hot water/steam as it used to.... I think is may be the heating element which has burnt out - any ideas? thanks
Sep 21, 2008 | Dishwashers
My dishwasher model dwh3 manufactured by Heller is displaying error 3
my dishwasher has the same problem what is the solution?
Jun 29, 2008 | Maytag Dishwashers
DISHWASHER HELLER DWH3
my heller dish washer has a error code e4 ? where can i find what this means
Apr 27, 2008 | Maytag 24 in. MDBH970AWS Built-in...
Dishwashers Logo
475 people viewed this question
Top Dishwashers Experts
