Question about Powerware 9120 UPS System
Fan is running constantly
I just moved my Powerware 9120 UPS from one location to another, and noticed the fans are running constantly. I don't recall if they did this at the first location. Should I be concerned? Unit wasn't dropped, tipped, or damaged in any way. I don't have the software to se if there is a setting that needs to be adjusted via a soft pot. Any suggestions?
  • 114 Answers
In the 9120 series the fan is allways working, but as 2 speeds. the higher goes of when the load goes around 80% or the temperature inside is higher. just make sure the the fans are clean, and check the ups temperature.
but is normal.
good luck
Posted on Jul 01, 2008
Can I replace the fan in a live powerware 9120?
hey dude your problem is so simple..below are my solutions.
if you already secured the fans for the replacement then its easy for you to do it, try to totally shut down your UPS removing the input and battery supply. avoid replacing the fans with power, its to dangerous. it consist of almost 400VDC inside in it.
call me if you want +63923 3024 585
Jul 11, 2013 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
Overtemp
The cooling fan is probably not working. Unit will overheat. Check the fan to see if it run continuously with no scraping noise with the UPS turned "ON". If the fan does not run, open the case and replace the fan.
Jan 19, 2010 | Powerware 9120 UPS System
Replacement fans for powerware 9120
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
Oct 01, 2009 | Powerware 9120 UPS System
Overtemp Condition on LCD
You're absolutely right, overtemp on batteries can greatly escalate the failure of batteries, particularly older or heavily loaded ones. The fans are a fairly easy replace, if we can assist in any way, please do not hesistate to contact us.
http://www.gowithon.com
Jun 19, 2009 | Powerware 9120 UPS System
9120 fan stopped working
On Services can assist you in the repair of this UPS fan and any other critical power service parts/repairs. We have nationwide service, please contact us if you are still looking for assistance.
Jun 12, 2009 | Powerware 9120 UPS System
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
301 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
