Question about Kenmore Kitchen Ranges
I have a kenmore elite 790-46603501 and there is an error code on it sab and my oven will not turn on
  • 413 Answers
The range has entered sabbath mode. Refer to owners on procedure for turning sabbath mode off. Also try to hold down "timer off" button for 10 seconds.
Posted on Jun 09, 2008
Kenmore electric range model 970 6362 SAB code.How do i reset this so the oven works again?
Hello. Try pressing and holding the "clock" button until the "SAB" starts blinking. It will then clear and the normal clock display will be showing--your oven is in "Sabbath mode" presently!
Sep 10, 2015 | Kenmore Kitchen Ranges
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
I AM GETTING A ERROR CODE ON MY STOVE SAB OR SA6 HOWEVER NONE OF THE BUTTONS WORK
This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
Mar 06, 2011 | Kenmore 46564 / 46565 / 465 / 6646569...
My kenmore elite microwave when turned on shows a f7 error code.
f7 keeps showing up and the microwave keeps cutting off,f7 code shows up. what do i do
Oct 26, 2010 | Kenmore 68361 Microwave Oven
Kenmore Elite oven error code SAb what is this?
I think you have entered "Sabbath Mode" which blanks the display ... check your owners manual to see how to exit this mode.
Jun 23, 2010 | Kenmore Elite 44173 30 in. Electric...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Readout is stuck on 5Ab. Can't do anything with it
Hi.
Regards.
Jul 09, 2009 | Maytag MEW6530D Electric Single Oven
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
Nov 21, 2007 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
397 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
