Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
The hot surface light is staying on and will not go off. Is there a way to fix this?
  • tim2508 Aug 09, 2008
    I have a Frigidaire Model # FEFS68CJSC The hot surface light is staying on and will not go off. Is there a way to fix thisI have only one light to indicate hot surface, How do I determine which element has failed ?
    Thanks
  • 413 Answers
Each element contains a sensor to detect when the element is hot, this sensor has failed. The element will have to be replaced. If there is only one light to indicate hot surface, you will have to determine which element has failed.
Posted on Jun 09, 2008
Kenmore elite model 790.4671 the front right hot surface light stays on all the time
There are a few more numbers in that model but I think if it is the largest burner not including the double part number is 318297805 always turn of the electricity before attempting any repair
Sep 30, 2012 | Ovens
On light indicator wont go out
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
Feb 08, 2011 | Maytag Ovens
My indicator lilght stays on even when the burner is off.
heatman101
Dec 13, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Cooktop on light will not shut off
heatman101
Sep 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 465 Surface Hot Indicator Light stays on all the time.
Most likely a faulty burner limiter switch. Not sure if they can be purchased separately from the burner element.
-Dave
http://www.appliancepartspros.com/part_details.aspx?part_id=3767588
May 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Pilot Light Wont Light
Take off the top cover plate inside the oven. Now with the door open turn the oven on does the hot surface glow? If it doesn't glow then you have a bad igniter and needs to be replaced. What ever you do don't touch the surface of the new igniter human oil will shorten the life of the igniter. now if the hot surface glows then the gas valve is bad and need to be replaced. I'm betting it's the hot surface.
Nov 25, 2008 | Amana Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
613 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
