Question about Frigidaire FRS26ZSG
No water to ice maker
I recently replaced the water filter. Now the water dispenser works fine, however the ice maker does not fill with water.
  • emil24 Jun 24, 2008
    THE FIGIDAIRE DOES NOT MAKE ICE, OR HAVE ANY WATER
  • RSCheung Oct 06, 2008
    Have you get your problem fixed? I have the same issue and still working on it. Any suggestion? Please help.
    No-so-handy from Boston
Be sure that the water supply is on, and that the plastic water hose is not kinked, blocked or frozen. Mine was twisted at the bottom left door hinge.Also, check the black microswitch behind the ice/water outlet. Mine was sticking. Just a couple bucks at any Electrical Supply distributor.
Hope this helps,
DrD
Posted on Jun 25, 2008
How do I "Prime the Water Supply System" refereed to in use and care guide that came with my new Kenmore French Door Bottom Freezer, #253.70413411. Cannot find instructions in the manual only reference to...
Assuming you followed the water line installation directions and you have water available to your new refrigerator/freezer here is the rest of the "priming" info you requested. (basically it tells you how to run a bunch of water through the system by filling cups or glasses to remove any debris and/or air...
Automatic Ice & Water Dispenser
Priming the Water Supply System
1. Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle. 2. Keep the glass in this position until water comes out of the dispenser. It may take about 1½ minutes. 3. Continue dispensing water for about three minutes to flush the system and plumbing connections of any impurities (stopping to empty the glass as necessary).
Ice Maker Operation & Care After the refrigerator is installed properly and has cooled for several hours, the ice maker can produce ice within 24 hours. The ice maker will fill the ice bin from the rear. You must dispense some ice to force the ice forward in the bin. This will allow the bin to fill completely.
Turning the Fresh Food Ice Maker On and Off Ice production is controlled by the ice maker's On/Off icon on the control panel. Press and hold the "Ice Off" icon for three seconds to turn the ice maker "ON" or "OFF". The ice maker is turned off when the LED above the "Ice Off" icon is illuminated.
Using the Ice Maker after Installation Before making ice for the first time, be sure to prime the water supply system. Air in new plumbing lines can result in two or three empty ice maker cycles. Furthermore, if the system is not flushed, the first ice cubes may be discolored or have an odd flavor.
CAUTION
For proper dispenser operation, recommended water supply pressure should fall between 30 psi and 100 psi. Excessive pressure may cause water filter to malfunction.
NOTE The water dispenser has a built-in device that shuts off the water flow after three minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle.
IMPORTANT On occasion, unusually small ice cubes may be noticed in the bucket or in dispensed ice. This could occur in normal operation of the ice maker. If you start seeing these more frequently, it may be an indication of low water pressure or the water filter needs to be replaced. As the water filter nears the end of its useful life and becomes clogged with particles, less water is delivered to the ice maker during each cycle. Remember, if it's been six months or longer since you last changed your water filter, replace the water filter with a new one. Poor quality household water may require the filter to be changed more frequently.
IMPORTANT Your ice maker is turned on at the factory so it can work as soon as you install your refrigerator. If you cannot connect a water supply, set the ice maker's On/Off icon to Off and turn off the water supply valve; otherwise, the ice maker's fill valve may make a loud chattering noise when it attempts to operate without water.
Hope this helps. Randy
Mar 02, 2015 | Kenmore Refrigerators
Water dispensing into ice maker won't shut off
There should be a float or electronic water level sensor that will tell the water to shut off, if it has calcium from the water on it or the float is damaged it will keep sending water until manually shut off(pull the plug). I would look for a water level sensor of some sort and clean or replace it. If that doesn't work it could be a sticking water fill solonoid which you should then replace
Sep 06, 2012 | General Electric GSH22JSXSS Stainless...
Water will not dispense to ice maker
The water dispenser in the door of my Kenmore side by side will not work. The ice dispenser does work. What do I need to do to fix it?
Thanks Kel
Sep 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
Automatic ice maker won't make ice
Turn off water.
Disconnect the line after the filter.
Turn water back on. If there is no water flowing, replace the filter.
If there is water flowing, the feed valve is probably defective.
Aug 02, 2009 | Kenmore Refrigerators
No water from the dispenser
You need to replace the dual solenoid one side is for the water the other is for the ice.
Jan 18, 2009 | Amana SXD524VW Side by Side Refrigerator
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Side by side frigidaire ice maker not working
Check the water valve at the back of fridge. Are you getting water at the dispenser on the door? If so, the water valve may not be bad, but sometimes water will freeze in the tube that fills the icemaker. Pull it out from the back of the fridge and check it.Hope this helps !
Oct 08, 2017 | Frigidaire FRS26R4A Side by Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Refrigerators Logo
165 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
