Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
ASUS M2N-SLI deluxe
When I turn on PSU green LED is on but, when I push the on button on case it comes on for about 2 seconds and turns off. The fans are running.
This is a brand new computor using ASUS EN8600GTS silent/htdp/256m video card also. I also have 5 hard drives 2 500gb,2 80gb and 1 250gb. Any help would be appreciated.
  • 2 more comments
  • Ricks Photos Jun 09, 2008
    OK I tried removing three sticks and same problem I also removed the video card.
    I rechecked all the PSU connections all good. I rechecked all sata connections at both ends and found nothing wrong. Rechecked all fan connections. Could there be a problem with the panel connections? I noticed when the power shuts off and I turn it back on quickly that the time it comes on for is shorter each time. It seems like something is shorting mabe?
  • Ricks Photos Jun 16, 2008
    Got the problem fixed. Thanks for the help.
    Ricks Photos
  • Ricks Photos Jun 19, 2008
    I fixed the problem. It was the second ATX plug on the mother board. Stupid mistake (left it unpluged).
    Thanks for the reply.
    Ricks Photos
Check your power supply had the same problem it turned out to be my power supply could not start under load
Posted on Jun 18, 2008
  • ASUS Master
  • 13,433 Answers
For start
lets remove everything non essential to start up the pc.
Try with only one memory.
recheck psu connectors.
Posted on Jun 09, 2008
  • Ekse Jun 15, 2008
    hey mate, could you also change the rateing on this topic, we solved the problem in the other one, but this is lowering the rateing % :-) since its still on thanks for trying (innapropriate, thanks for trying are kind of negative on the % == Helpful and fixya are postivice on the %) Thanks!
Asus m2n-e sli no start
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
Dec 06, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Need audio installer asus m2n-sli deluxe
If it is: M2N - SLI Deluxe:
if: M2N - SLI Deluxe/Wireless Edition
select your OS
Aug 06, 2010 | ASUS M2N-SLI Deluxe Motherboard
ASUS M2N32 SLI Deluxe - Fans Come On But Board Doesn't Post
there should be a four pin connector from the psu to the mobo,if thats not it try removing memory sticks one at a time, just make sure you leave one in
Apr 09, 2009 | ASUS AI Lifestylestyle M2N32-SLI...
Asus m2n sli deluxe sli 1 is 16 and 2 is 8 how to work 8 8
Feb 05, 2009 | ASUS M2N-SLI Deluxe Motherboard
ASUS M2N-SLI DELUXE 2 hr "warm up"
Try changing the Motherboard battery it could be flat
Oct 31, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
M2N- SLI Deluxe Motherboard won't power-up
Look for blown capacitors. Check this site for example pics.
Jun 29, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus m2n sli motherboard
That single beep is most likely POST. Power on self test. You're board, Asus M2N-E SLI uses an Award bios. The beep error codes can be found at this link:
If you are using a single PCI-E card, check that you have the bios set correctly. Shown on page 4.4.6. Do you have you're memory in slot A-1 & A-2? Check that you have PCI-E set for primary display adapter, pg 4.4.4
For windows XP Pro with out SP2, please disale ACPI in you're bios. After SP2 & updates, you can turn it back on. It's realy odd that you're high power PSU did not come with an ATX 4-pin_12v connector for the board. (Needed for CPU).
This is a standard feature for current PSU's. Can you swap the PSU? Considering what devices you are running. You can easely run a 350w PSU? This swap would only be used as a test. Next test, go into the bios & go to Advanced, CPU configuration, check hardware monitor. Stay here a bit & watch temp settings.
Go over these suggestions. Let me know if any one of these suggestions has helped? Can you see the drive in you're bios?
Jun 06, 2008 | ASUS M2N-E SLi Motherboard
Serious problems with an Asus M2N E SLI motherboard.
I understand how this must be driving you nuts. What I am going to suggest might sound stupid but I have to ask. After your assembly was finished (1st time around) did you check the 4-pin ATX + 12volt connector was correctly & fully inserted into the board? Pg. 2-28 section 6. in your manual? Did you add thermal grease to the CPU. A bad pin on the CPU will give you this symptom. I completly understand if you do not agree with this next part but it is extreamly important you go with it. Take the static bag your board was wrapped in & lay it on a table. Place a piece of foam on the static wrap & place your motherboard on the foam. You can use books instead. Connect your PSU, CPU heatsink & fan, Hd & video card & 1dimm to motherboard. Connect mouse, keyboard & monitor.
Check that PSU is set for 115v (small red slide switch near the off/on toggle switch). Plug in the PSU to outlet.
If the green led on board lights up you have power to board. This is known as a standby led. If it's not on, flip the toggle switch on the PSU to on.
Use a pen to short the power switch. This will turn on the board, no different than you pressing the power button on your case. Goto pg. 2-30 in your manual. Find PWRSW two pins. If the system starts up than somewhere durring install the board was shorted to the case.
Feb 16, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
have you tried removing all other hardware like your graphics card and all other peripheral cards even memory and booting to see and eliminate all other components?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
try the board with out memory and hard drive.
Do fans run?
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
156 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
