Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Water filter whirlpool fridge
Where do you replace water filter
Ice maker want stop water from running
Posted on Jun 28, 2008
    President:
  • 1,314 Answers
Look on the bottom kickplate for a round peice unscrew it and replace the filter
Posted on Jun 11, 2008
I need help with my whirlpool ref water filter replacement.
Need more info on what type of fridge it is. Side by side with the water filter at the bottom with the push button on the left. Push it really hard and the filter ejects from the housing. Or if it's in the ceiling or top of the fridge inside the fridge compartment. You lower the cover, then lower the filter (will still be hooked up) then grab the filter with with both hands. One in the back to twist and the other on the front to keep it stable and in place. If you twist from the back and don't hold the front. It will snap that plastic that the filter goes into. Which we don't want to happen. After yiu replace the water filter. Make sure you dispense at least 1/2 a gallon or a full gallon of water out or the water dispenser to get all the air out of the water line. Having air in that line can and will cause a bunch of other issues later on.
Hope I was a little helpful my answer.
Oct 07, 2016 | Whirlpool Refrigerators
What type/model/ brand of water filter do I need for the Whirlpool Roper side-by-side refrigerator with the model number: RS25AGXNQ00
There is a generic type of water filter that fits all Whirlpool and KitchenAid refrigerators with a water filter located in the base grill below the door.
it looks a bit like this: http://www.partselect.ca/11722132-2-M-Whirlpool-EDR5RXD1-Water-Filter.jpg
Here is one on amazon: Amazon com Replacement Roper RS25AGXNQ00 Refrigerator Water Filter...
Sep 05, 2016 | Whirlpool Refrigerators
I have a Whirlpool fridge that needs a new water filter. Twice now, when I remove the filter to change it, water gushes out even though the ice maker is OFF. I quickly turn off the water line and mop
The Whirlpool fridge requires a water supply connection to a cold water line. Before you connect the water supply to the water line on the fridge, make certain the unit is unplugged from the wall. Press the button and drop down the cover. Then twist to release the old filter and twist the new one into the filter head. Run about 2 gallons of water through dispenser to remove any air from the lines. Liquid EPDM Rubber Roof Coatings for Roof Leaks Repair EPDMCoatings
Jan 29, 2014 | Whirlpool Refrigerators
My whirlpool fridge freezer is not producing water from it the ice is not refilling there is water getting to the fridge freezer as we have check the water input.
Check you filter, if it has been more than a year it is blocked. It might also be a broken pump or froozen water line. I would start with replacing the filter then the pump and if no luck a heater kit
Dec 21, 2010 | Whirlpool GD2SHGX Refrigerator
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
I have a side by side whirlpool water filteration system fridge and I need to know how to replace the water filter on the fridge
I can only guess because I don't know your model number. At the bottom of the fridge at the front there should be a round knob or handle about 2 to 21/2 inches, you should be able to turn this and pull out the long filter tube, take the number off it and get a new one.
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My new Whirlpool Refrigerator the water and ice still stink
We have the same problem. Started 2 weeks after purchase. (6 months ago). Tech. replaced fliter, worked for another 2 weeks, then water & ice awful again. Tried to live w/ it - ordered another filter a week ago. Replaced & within 24 hrs. problem was back. Called Whirlpool. Said tech who came to my househad written in his report that tap water & fridge water tasted the same. A lie - he agreed w/ me that the water from fridge was bad, & replaced filter which had a musty odor. Whirlpool basically called me a liar but agreed to send another tech to check it out. I will never buy another Whirlpool product & plan to tak this problem as far as I need to in order to get satisfaction. This is ridiculous!
Dec 19, 2008 | Whirlpool Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
122 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
