Question about Toshiba (FSRMCP0001) Remote Control
Toshiba remote control
Channel selection button will not work
  • gwhite8381 Jun 09, 2008
    no, settings aren't wrong the switch was flipped on the bottom to dvd. I fixed it myself.
  • Toshiba Master
  • 13,433 Answers
Is this a universal remote controller? try another code.
other than that there may be a fault in the remote or settings are wrong.
Posted on Jun 09, 2008
  • Ekse Jun 09, 2008
    Yeah the setting was wrong..
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
Can get only 1 channel to program on my toshiba
hi if the tv has dtv just select air digital only thanks
shaun
Mar 25, 2017 | Toshiba 40RV525U 40 in. LCD TV
Can select channel by entering the # but when using the up/down channel arrows, goes straight to channel 3
You are using a universal remote control I assumes. Try with an other setup code. Some setup codes might not work for all button actions properly. Choose an other code, which will give you maximum functionality.
Jul 05, 2012 | Toshiba Ct90325 Remote Control
Need a code for 37bv700b for sky remote number not on sky list
Hello
Toshiba has a lot of codes to check with Sky remote. They are:
536 063 271 098 117 232 530 581 130 473 088 182 064 216 253 508
536
581
216
253
063
746
726
508
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
OK.
Jul 21, 2011 | Televison & Video
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Jan 02, 2011 | Toshiba 27AFX54 TV
Toshiba 42h82
1. ENTERING TO SERVICE MODE
MUTE
S
(Service mode display)
3) While pressing the MUTE button,
press MENU button on TV set.
2) Press MUTE button
again to keep pressing.
1) Press MUTE button twice
on Remote Control.
2. DISPLAYING THE ADJUSTMENT MENU
1) Press MENU button on TV.
Adjustment mode
Press
Press
Service mode
Item
S Data
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Oct 21, 2008 | Televison & Video
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Televison & Video Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
