Question about Eureka Enviro Steamer 310 Stick Vacuum
Eureka Hotshot Enviro steamer
After a long period of non-use, my steamer nozzle is clogged. I soaked in vinegar and water, then heated up. Still cannot unclog nozzle. A small bit of steam came out. I will soak overnight, but not sure how to safely and effectively clear nozzle. Is there a deposit removal product i can run through it?
Thanks,
gbmeerkat1
  • 1 more comment
  • idontchkmyma Jul 22, 2008
    It gets hot but nothing comes out! tried blowing in it with handle depressed, no air goes through. tried a toothpick. tried less water.
  • sea_y_sol Dec 10, 2008
    I love my Enviro Streamer, but mine too has stopped working after it was stored post move. The water definitely heats up and the pressure builds up, but nothing comes out - no steam at all.
  • Anonymous Mar 31, 2014
    I let my Steamer sit in the garage for a couple of years, and did not know that my son used it without properly draining water from it. I never used tap water, but I assume he did, since there is white deposits all over the inside. My steamer is not holding enough steam pressure plus its spitting water all over. I'd like to know how to safely clean the tank to rid all these deposits. Thank you
  • 59 Answers
Remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Posted on Oct 26, 2008
I ned at instruction book for electrolux enviro multi steamer
You didn't specify which model you had, but I assume it's the newer Eureka Enviro Steamer Model 313A.
Here's a link to the owners manual for your Steamer. If you have an older Enviro steamer, please feel free to reply using the comment field below. Also, if you found this solution helpful, please be sure to leave feedback for me. Leaving feedback is greatly appreciated by the FixYa community, and ensures that repair experts continue to leave great FREE advice, as opposed to just answering the premium, or paid questions.
Hope this helped you, thanks again.
Eureka by Electrolux Enviro Steamer Owners Manual for 313A
Jan 07, 2011 | Vacuums
My unit was working perfectly, then all of a sudden the heating unit quit. It's only two months old. What happened?
It's still covered by warranty, so I suggest taking it to where you got it. If they don't have a warranty station, you can find the nearest one on the below site.
http://www.eureka.com/Customer-Service/Store-Locator
Oct 05, 2010 | Eureka Deluxe Enviro Steamer Vacuum
My Eureka Deluxe Enviro Steamer doesn't steam, I had no directions with it so I'm not sure how much water to put in it. It comes out the bottom before it heats up sometimes.It never seems to get hot...
You will need to pour two measures of water using the measuring cup or 12 oz of water. The reason why water comes out of the bottom is because the floor cloth is too wet or you had too much water in the tank
Click on the link below to view the owners manual:
http://www.eureka.com/service/manuals/70359.pdf
Jun 22, 2010 | Eureka Deluxe Enviro Steamer Vacuum
Need directions on how to clean clogged steam nozzle
If your steam mop is Enviro Steam Mop by Eureka. remove the 2 screws on the bottom of the steamer, that holds the center panel on. (Not the screws that hold the whole bottom.) Use a needle the clear the steam holes. Soak the panel in white vinegar for a couple of hours and scrub with aa brush to remove the lime calcium deposits. Check the center hole that goes into the steam and make sure it is clear. Reattach the panel. If the panel does not fit snuggly (either end does not contact the base panel, add two more screws about an inch in from either side. I used stainless steal screws because of the consist moisture. Used screws that are no more than 3/4 on an inch long and about the same diameter as the two you removed.
Apr 06, 2008 | Eureka Enviro Steamer 310 Stick Vacuum
Eureka Enviro Steamer 310 Stick Vacuum Logo
2,190 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
