Digital tv Hi, my tv gets fuzzy and audio drops out when the central heating kicks in. How do I fix it? Thanks
    Problem Solver:
  • 8 Answers
First.............. check ground of cable and circuit
second.......if ground is ok extension cord to different circuit and
test
third .........if problem cont. call heating & cooling co.
please reply when you find out
and use your power to vote
p.s GOOD LUCK!
Posted on Jun 09, 2008
Hello! My Panasonic QuintrixSR picture becomes fuzzy then thick squiggly black lines appear. The whole screen turns black yet sound still on. Can I fix this or is the TV toast? Please help, thanks.
Hi there!
Your tv is not toast yet it can be fixed. get another screen and see if their any changes .if other circuitry are fine your screen should work perfectly
May 18, 2017 | Panasonic Televison & Video
Audio problems - great picture -fuzzy sound
yes..that would make sense..the cable is getting dried out, and has less conductivity when it's hot or warm..that's not unusual
Feb 29, 2008 | Sony KP-57WV600 57" Rear Projection...
How do i fix a fuzzy picture on dvd recorder play back
What is the resolution of the recorder? If it isn't Hi definition, then you'll never get a really clear picture. OK for older TV's but not Hi Def. You can get a 2 position A/B switch and connect the audio and video OUTputs of the cable box to one side of the switch and the other side to the AV out on the TV.
Aug 09, 2017 | Televison & Video
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Central heater kicks off and on constantly
It is a strong possibility the flame sensing electronic thermocouple has become contaminated. Buildup on it causes malfuctioning like you described. To remedy it you simple remove the flame sensor and clean it with steel wool. here is a video I found on line:
Furnace cycling frequently
Jan 06, 2010 | Mr. Heater Model MH12TS - Single Tank-top...
My honeywell central heating system turns off on its own. I set the room temp., the heating system reaches that temp then just turns off. The temperature drops and the system does not kick back on again to...
Hi, Just to let you know I have repaired central Heat & Air systems for 33 years and Have seen this problem on many occasions. Lets see if I can save you so many trips.It says you have a programmable stat? On this stat and on a mechanical stat, they have what is called a heat anticipator that controls how many and how often your thermostat turns you're unit off and on and how long it cycles after the stat is satisfied. If you have ever seen under the cover of a mechanical stat, ( mercury switch type) you will see a dial with an arrow with numbers as .1, .3, .4 1.0, or .15 to 1.0 amps.Some are fixed and some are adjustable. On a digital stat, you will have to get into the program and see what the heat anticipator is set on. They come from the factory at .4, but to really find out what you'res should be it takes an amprobe to do this. The setting you need is what you're gas valve requires.I am sure I have lost you, but I am just giving you a little food for thought. If you can get into you're program and set this to .4, great. If the problem continues, your anticipator on this stat is more than likely, shorted, which would require you to buy a new stat.With a shorted anticipator, it will seem to be working like you say, but when satisfied, the temp.keeps falling until you reset power, then it fires and repeats this. Change the stat. If this is central heat and air, just follow red-rc which will have a red jumper to rh for heat, white to w, green to g=fan, and yellow or blue to y = cooling. If you have central heat only, you will find 2 wires red and white.Red to rh with jumper still installed to rc and then white to w.This is quite a long explanation, but I wanted you to know a little more then the next guy about your stat. Please let me know.
Sincerely,
Shastalaker7
Nov 12, 2009 | Honeywell Programmable Thermostat Heater
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
Only plays picture when fast forward.
Cleaning or video head replacement time....accordianman
Feb 11, 2008 | Zenith VRB420 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
