Question about Canon PowerShot A640 Digital Camera
Need to replace the circuit Board.
I have a Canon A640 and need to replace the circuit board. Can anyone tell me where to order this from.
  • taddy28 Jun 09, 2008
    Thanks for the info. I was hoping to pay "internet" pricing for this item. Usually the manufactor has inflated the price of everything.
  • 130 Answers
You can call Canon tech support and be transferred to the parts department.
Hope this Helps!
Posted on Jun 09, 2008
Plasma TV LG 50PX950-UA image flashing
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Mar 07, 2016 | LG Televison & Video
I have a canon powershot a640 but it only takes pictures if the flash is off. How do i fix this ?
Sounds like the flash capacitor is not charging. Usually the cause is a blown fuse. This is a hardware problem, not software, and the only solution is to take it apart and replace the fuse (it's a SMD fuse and it has to be soldered). Sometimes the problem is with the flash board. I'm afraid you will have to give it to a camera technician. I could help you with the repair, but I'm in Germany.
Mar 05, 2011 | Canon PowerShot A640 Digital Camera
I need a new screen for my canon powershot A640 ASAP.Mine is smashed for the second timme. Where could I possibally get1?
If you're confident you can do the job yourself, you can order the part from
Dec 11, 2010 | Canon PowerShot A640 Digital Camera
Need Circuit Diagram, or convergence resistor list for PT51D31CE
they are 2.2 ohm , i have replece many of this before
Apr 19, 2010 | Panasonic PT-51D31 TV
Canon powershot sd1100 water can i fix?
You really can't....however, there is a very small chance that it might work but you need patience though. First you need to take the battery and the casing off in order to expose the circuit board. Secondly if you can find a dehumidifier, you should run the dehumidifier and place the camera in front of it for 72hrs with no interuptions. Lastly, put the camera back together. Hope this will help. If not, the circuit board has short circuited itself and there is no possible way to replace any components.
Jul 07, 2009 | Canon PowerShot SD1100 IS Digital Camera
Camera putting double of each picture on Card
There is a board in your camera that has the SD card port on it. It is most likely at fault and need to be replaced.
Jul 01, 2009 | Canon PowerShot A640 Digital Camera
Lens does not zoom in
This is not a common error on canon digital. This is caused due to possible short in zoom control circuit (main pcb). At normal use, if the lens does not retract due to mechanical jam, when the zoom control button is pressed, lens error 18 message supposed to be displayed. Since control circuit is shorted and faulty, error 18 message was not displayed. The remedy for this problem probably requires a replacement of a main pcb. Replacing a main circuit board may run around $100-140. -James
Mar 29, 2009 | Canon PowerShot A640 Digital Camera
How do I clean the interior of the lenz for Powershot A640
Its a big job, If your petty handy, You have to start from the back of the camera, Remove rear cover,Then front cover, Next lcd Display unit, Hopefully your haven\'t put the battery\'s in the camera for a while because the flash has high voltage in it, if you have, You must discharge first, them take circuit board out,Then lens assy, Now the fun part, You have to take the lens apart from the back also, Like I said its a big job, Better when you get this far into the camera you just replace the lens, with a used one form a diff camera (same model )
Feb 25, 2009 | Canon PowerShot A640 Digital Camera
Samsung HL-S6187W 61 in. HDTV black screen on the right side
If you found a bloated capacitor on the circuit board, that one needs to be replaced not the board. You can see the part number on the capacitor itself. Also please look for any burned IC and neighboring components. If you found additional burned components, it also need to be replace. Contact a pro tv technician to replace it.
Order parts here:
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
Canon PowerShot A640 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
