Question about Haier HWR06XC5 Wall/Window Air Conditioner
Starting unit for first time of season
If the unit has been stored on its back for the last 6 months, how long before I can run it for the first time?
  • 828 Answers
8 Hours should allow the oil in the system to resettle. Then you can restart or place it in operation. They should be stored on the base.
Posted on Jun 08, 2008
When does Longmire season 6 start
A certain release date is not sure yet however it is believed to begin this month. Check out this article all about the new season of Longmire.
Longmire Season 6 Release Date Spoilers Trailer Cast Plot Episodes 2017...
Oct 01, 2017 | Computers & Internet
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
No get up & go
This unit runs a Hydro-Gear transaxle. These are normally pretty good units. Have the service guy check the fluid level and belt a stretched belt can also cause this issue.
May 23, 2017 | Craftsman Garden
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Mantis won't keep running
if unit has bean stored with fuel in it during off season you will need to replace the carburator the symptoms described suggest bad fuel you may get lucky by dumping the fuel tank purging carb. then add fresh fuel otherwise replace carb. e-10 fuel generally last a max 3weeks without stabilizer
Apr 11, 2010 | Mantis 2-Cycle Tiller
Starter problem 1991 honda accord
i'm sure you're just having bad luck buy new one
May 14, 2009 | 1991 Honda Accord
Yardbroom II pull start hard to pull
put a teaspoon of mix oil into the spark plug hole, some times the metal starts to bind in the engine. keep the wire off and the plug in and pull the cord a bunch of times until it starts to get easier, if you need to add more mix directly to the hole then do it. hope this helps
Mar 28, 2009 | Homelite 'Yard Broom' Leaf Blower
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
When turned on, the unit sounds like it will start then turns off within a minute.
Presently according to my information there is no recalls for Fedders products at this time for this model type.
May 27, 2008 | Fedders A&B Chassis A1A07W2B Air...
Gps module
I just went through this with Lowrance. tthe LGC 2000 module on my LCX 20 depth finder "quit responding" out of the clear blue. You have to go Lowrance.com and they have some tests you can follow to see if it is a bad cable or the module itself. I had to replace the module. They charged $99 bucks plus $12.50 shipping for a new one. I bought it spring of 2008, and the unit was 3 months out of warranty when it quit working. Last season I had lower back fusion and didn't use it except for 2 times late in the season. Getting ahold of Lowrance is going to be an experience. I called twice and waited on hold over 35 minutes before I was suddenly cut off both times. I tried email too, but it took 3-5 days to receive a response. Mine broke down June 18 of this year. I started trying to get hold of Lowrance the next day. By the time all the back and forth emails with the delayed responses were done, I received my new unit on July 24. 5 weeks! with out my gps in MN. It is a short season up here as it is. I sure didn't enjoy waiting that long.
Oct 19, 2007 | Lowrance LGC-2000 GPS Unit GPS Receiver
Haier HWR06XC5 Wall/Window Air Conditioner Logo
111 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
