Question about Hotpoint RGB745 Gas Kitchen Range
Oven ignites by itself
We have a Hotpoint electronic ignition gas range (don't know model #), where would that be located on the range?
The oven comes on all by itself....this happened last month when we were not even home....now it comes on and stays on all by itself, no one even in the kitchen. we will smell something "hot" and go to the kitchen to find the oven on, today we had a hard time turning it off.
the knobs are in "bake" and "OFF" possitions...what would cause this, it is very scarey....
thank you
  • 1 more comment
  • Anonymous Jun 18, 2008
    I Came home after being gone from home for two days and found the oven on, smoked and burned up
  • mikegrace195 Nov 30, 2008
    I have a Hotpoint, Electronic Ignition gas stove Model # RGB744GEV2WH. It reignites by itself after being turned off after using the oven. This has happened three times so far. We have been fortunate to catch it and tinker with it to turn it off. To get it to turn off we have had to turn it back to "on" in the bake mode and then the "on" indicator light and burner will go off. We leave the oven door open to dissipate the heat. The oven cools down and the oven does not come back on.
    Any ideas as to which part is malfunctioning?
    Mike
  • thebyrds Feb 07, 2009
    the oven wont shut off when turned off. still stays on. please advise. thanks, the byrds
Any chance that the plastic knob was cracked and not really turning the shaft of the thermostat?
What did you find the problem. I know this response is 2 months after the last post above.
Eddie
Posted on Jan 26, 2009
I have a Hotpoint gas range that has electric ignition for the oven. However, I don't have electric at my cabin. Is there a conversion kit for a straight pilot ignition available? The model number is...
Most gas ranges with electronic ignition aren't equipped to have a straight pilot ignition.
I'm don't even think they make conversion kit because of the routing of the gas tubing for the pilot source.
Usually you have to turn the gas knob way over to get the "click-click-click" of the igniter.
Its just as easy to turn on the gas and light with a match...or a long butane lighter.
Even a "striker" used in welding will provide a source of ignition.
A last ditch effort would be to get a replacement gas grill igniter...all ya gotta do is place the bottom of igniter on metal surface and press red button. (kinda works like a spark plug) and no A/C needed.
Hope this helps some.
Jul 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven modle # rgb746hed2ct oven does not come up to proper heat or maintain heat
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Mar 29, 2011 | Hotpoint RGB745 Gas Kitchen Range
RGB745wea7ww gas oven comes up to temp but wil not hold temp. Igniter will turn on but gas will not light. I have replaced the oven sensor and igniter. Same problem. Igniter attempts to lite gas but no...
Oct 20, 2010 | Hotpoint RGB745 Gas Kitchen Range
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    When you turn oven on only the heating element comes on but not the gas.Egnighter glows red but no gas and no sound from the gas valve.
    You may have a simple problem of a defective igniter. The following link explains a little theory about igniters and how to access the them on a gas range:
    http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
    If you are having ignition problems with one of the oven manifolds (bake or broil), it may be a simple matter of a weak or bad igniter. Just because an igniter glows, does not mean it is good. If the igniter is weak, the gas safety valve will not open and gas will not flow.
    NOTE: If BOTH manifolds were experiencing the same problem, you would potentially have had a bad regulator or electronic oven control (EOC) board. The EOC controls all your oven features.
    A replacement igniter for your range can be purchased at any of the following websites:
    searspartsdirect.com
    pcappliancerepair.com
    appliancepartspros.com
    repairclinic.com
    If the model number is correct, the part number for a replacement igniter is 74007498. The part should also come complete with installation instructions.
    If you require additional assistance, please let me know. If your model number is different, please post back with a COMPLETE model number (usually located on a nameplate around the oven door, or lower drawer opening) so that I may assist you further. Some manufacturers place the model number on the back of the operator console.
    I hope this is helpful to you.
    Nov 25, 2009 | Maytag MGS5870 Gas Kitchen Range
    Oven only working when on broil
    repairclinic.com
    If the model number is correct, the part number for a replacement igniter is WB13K21. The part should also come complete with installation instructions.
    Nov 25, 2009 | Hotpoint RGB790SEHSA Gas Kitchen Range
    Broiler and stovetop work oven does not
    You may have a simple problem of a defective igniter. The following link explains igniters and how to access the them on a gas range:
    pcapplaincerepair.com
    repairclinic.com
    The part should come complete with installation instructions as well.
    If you require additional assistance, please let me know. Please post back with a COMPLETE model number (usually located on a nameplate around the oven door, or lower drawer opening) so that I may assist you better. Some manufacturers place the model number on the back of the operator console.
    If you have any questions, please let me know. I hope this is helpful to you.
    Nov 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Maytag oven won't ignite, broiler o.k.
    A replacement igniter for the model number you have this question posted under is 12400035. The cheapest web site I could find it listed was pcapplaincerepair.com and appliancepartspros.com for about $40. The part comes complete with installation instructions as well.
    If you require additional assistance, please let me know. If your model number is different form the one listed, please post back with your correct information so that I may assist you better. The model number should be located on a name plate around the oven door, or lower drawer opening. Some manufacturers place the model number on the back of the operator console.
    Nov 22, 2009 | Maytag MGR5750 Gas Kitchen Range
    Hotpoint Gas oven doesn't light
    Is the gas valve easy to replace on a gas oven?
    Nov 14, 2008 | Hotpoint RGB745 Gas Kitchen Range
    Hotpoint RGB745 Gas Kitchen Range Logo
    406 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Justin Duby
    Justin Duby
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
