Question about Acer Aspire 5100 Notebook
Acer Aspire 1690 Audio output not working
Audio output for headphone connection or speakers does not produce any sound. However, speaker system works just fine. I've had problems with the port for the powersource on the laptop itself, so it shorts out constantly and have been through 3 powerpacks. (the problem i belive may be relative to the lack of audio possibly) any solutions for either?
  • 8,596 Answers
For audio output: I would locate the latest audio drivers for your speaker system - a few possible solutions:
1)Best: Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> Sound, video & Game controllers - look for a yellow exclamation mark by any of the devices, right click that device and click install drivers [note - this procedure will also work for your port problem, most likely; if not, just remove the port, restart your computer, and the "found new hardware wizard" will re-add it properly upon startup]
2) just enter the manufacturer nad model number of your spekaers in search bar and include the word "drivers" as your search term.
3) Go to www.driverguide.com
Posted on Jun 11, 2008
Acer aspire no sound through speakers
Have to change the audio settings to speakers from headphones
Mar 04, 2015 | Acer Computers & Internet
Where is the audio output on my aspire 4540
how did you connect external digital speakers when you cannot find the audio out port.that is the port where you connected.ok. try installing drivers for your system to get sound
Apr 07, 2012 | Acer Computers & Internet
Is my sound card damaged? My sound driver is present and i think it's working fine, sound bars are moving also when i drag the slide up and down. But, theres no sound coming from built-in speaker...
Based on the information you have provided, it seems that the issue might be with the Audio Output Jack.
Usually some Computers have an additional Audio Jack on the CPU.
If you have such an option you can try connecting the Speakers and Headphone to that Audio Port and check.
If you do not have an additional Audio port, then it is confirmed that the issue is with Audio Output Port.
It is recommended to replace the Sound Card. You can also check with your favorite Computer Retailer, if only the Audio Output Port can be replaced.
Please let me know if you have further questions or need any assistance.
Suresh....
Jul 29, 2011 | Acer Aspire 5535-5050 Notebook
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
Problem in external speaker when connected to acer 5738Z LAPTOP
The audio jack on the laptop is for headphones and most likely cannot it cannot deliver sufficient power to drive unpowered speakers.
Check the audio jack with headphones, if the volume setting is high and you still can't get sounds from the headphone and the mute switch is not selected then the audio amp in the laptop is faulty.
Jul 07, 2009 | Acer Aspire 5920-6727 Notebook
No sound
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 18, 2008 | Acer Aspire 1690 Notebook
My speakers are not working I need help
go to the control panel ... first under the device manage in system / hardware check that the drivers for your sound card are installed .... next go to the sound section in the control panel and make sure the proper device is selected fro playback ... make sure nothing is muted ... other things that can mess up your sound include onboard sound disabled in BIOS, bad connections or bad speaker power supply ... also you can test the audio output using headphones
Mar 29, 2008 | Acer Aspire™ T180 PC Desktop
No sound output from rear speaker jack
Plugging headphones into the computer will disable sound output from the sound card by design.
Sep 15, 2007 | Acer Aspire L100 PC Desktop
Acer Aspire 5100 Notebook Logo
402 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
