Question about GE Profile JVB67HWW 36" Telescopic Downdraft Ventilation System: White on White Kitchen Hood
GE Profile Telescopic Downdraft JVB37HBB
My fan still works  but the Telescopic feature does not.  I just stays up  but won't go down.  Has this happened to anyone before?  How do I fix it.?
Mine just did this this morning..a few months ago the button to make it pop up stopped woring so i just started using the wires to operate it...this morning it got stuck uo...i took off the electrical cover and found a burnmark on my circut seems a diode fried or still looking for a replacement
Posted on Jan 17, 2010
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
Jxb37 won't lower
My unit always goes up. Sometimes it doesn't go down. Then, after some time it goes down. Could it be the capacitor is bad?
Mar 10, 2014 | GE Profile JVB67HWW 36" Telescopic...
I need the small control module for a GE downdraft telescopic vent, part no. 959-0138-003 (ACT, Inc.). GE page does not recognize the part number. Where can I get this part?
Does anybody know where I can get a copy of the schematic for the control PC board P/N 959-0138-003 by ACT, Inc. for the GE Downdraft Vent model no. JVB98SH1SS?
Thank you.
Oct 20, 2012 | GE Profile JVB67H Kitchen Hood
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list -
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Ge downdraft vent
try removing the switch from the ribbon connector, and then jumping the two pins momentarily with a screwdriver blade or other metallic tool. It could be that the switch itself is bad. This is the same problem I'm having and I am currently looking for a replacement switch online.
Jan 23, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
GE Profile Telescoping Downdraft system gets stuck.
try to remove your cooktop and see if the vent unit is in your countertop too tightly. by removing the cooktop it will give the vent more space. if it works that way, then you might have to make more space for both to fit properly. i have seen this happen before and its probably what is causing it to bind and then drop suddenly. i hope you dont have a marble, slate or rock type countertop as they are very hard to trim just a little off to get everything to fit.
Jan 07, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
Wouldn't raise
The GE repair guy came and fixed our vent! He opened up the cover and found that the pivot arm was above where it was supposed to be. It had gotten dislodged or something. He replaced the pivot arm with a new one, Part #WB02X10303, which is supposed to be a new design that won't get off track so easily. Works great now.
Oct 03, 2008 | GE Profile JVB67HWW 36" Telescopic...
I just found the part that I think you need. It's part no. WB7X7220
It's available through the GE parts and accessories store.
Sep 04, 2008 | GE Profile JVB67HWW 36" Telescopic...
Kitchen Ranges Logo
1,133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
