Question about Goldstar MV-1515 Microwave Oven
Plastic filter cover
How do I remove the plastice filter cover on the top front of the micro?
There are 2 screws on the top of the unit. Once these are removed the cover comes right off.
Posted on Dec 15, 2008
How do i remove the plastic cover to change the light bulb in GE Microwave
Hi, I have a ge modle jvm1631 and mine has two scerws in the front of the cover (can be hard to see in dim light) on some modles you might have to have door open and screws will go in from bottom of cover. Then there is a filter inside that you take out and remove a metal plate that covers bulb.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Should the plastic covering on front of kor-63mdc micro door be removed ,leaving a mesh front
NO! It provides vital protection for the metal mesh.
If it is damaged or gone, grease, food particles and moisture will accumulate on and damage the mesh, then microwave leakage is possible, which can result in a fire.
If the plastic is damaged or gone, it must be replaced. You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Jun 18, 2010 | Daewoo Microwave Ovens
Message to change filter but unit exhaust up to stack?
Grease filters change from the bottom side of the unit.
Charcoal filter is changed as follows:
To Remove Charcoal Filter
To remove the charcoal filter, disconnect power
at the main fuse or circuit breaker panel or
pull the plug.
Remove the top grille by removing the screws
that hold it in place and sliding the grille to the
left (opening the door makes grille removal
easier). Slide the filter towards the front of the
oven and remove it.
To Install Charcoal Filter
To install a new filter, remove plastic and other
outer wrapping from the new filter.
Insert the filter into the top opening of the oven as
shown. It will rest at an angle on 2 side support tabs
and in front of the right rear tab. Replace the grille
and screws.
Aug 20, 2009 | GE XL1800 1100 Watts Microwave Oven
Changing filter
The grease filter is changed from the bottom of the unit.
The charcoal filter is changed as follows:
pull the plug.
oven and remove it.
and screws.
Aug 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to get sharp r-1440 disassembled from under
Probably don't need this anymore, but there is another post, which we added to. Hope you had success.
Be sure to unplug first.
It is mounted on a steel bracket which the micro was tiled into place on. The bracket covers the entire area of the wall where the micro sits.
Basically, two screws in the bottom of the overhead cabinet, and two more screws located in the venting area of the microwave (under). Take the vent filter covers off each side, and remove one screw on each side carefully. If you take the fan cover off in the top front, you can see the steel support on the left.
Two people: The micro is then lifted up and off the support slightly, and then tilt forward to remove.
Jul 15, 2009 | Sharp Microwave Ovens
GE JVM1860SF001
Be sure the oven is unplugged.
There are two Phillips head screws on the very top of the outside of the cabinet above the vent.
When they're removed the vent grille just snaps out.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 12, 2008 | GE JVM1860 Microwave Oven
How do I replace the door handle on microwave?
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Sep 03, 2008 | GE Advantium 120 Convection/Microwave Oven
Replace light in overrange GE microwave
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Jul 25, 2008 | Microwave Ovens
Microwave Ovens Logo
76 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
