Question about Kenmore Heating & Cooling
I need to know how to light the pilot on my somewhat old water heater. The model is called the challenger 5 the model number 153.331471
  • 828 Answers
On these older gas water heaters there is a gas control with temperature selection and below that is a removable cover. Once you remove the cover you can gain access to the pilot. You must rotate the knob on the top of the control to the pilot position. When in the pilot position, hold the red button down and light the pilot. Continue to hold the button down after the pilot is lit for about one minute. If when you release the red button the pilot goes out, try one more time. If it goes out again after releasing the button your thermocouple is bad and must be replaced. The thermocouple generates a millivolt electrical current that hold the gas valve in the operating condition when the pilot is lit. When the pilot goes out there is no heat to generate this small electrical field.
Posted on Jun 08, 2008
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
The heaters instructions say to open the heater, but i don't know how.
1) For real?
How can we answer the question without model number, brand and type water heater?
Is this a boiler? Or tank-type heater. Is the thing 2 years old or 12 years old.
2) Look on label on side of tank. Include all information shown on label.
3) Attach a photo so we can see the problem more clearly.
4) Call service technician or plumber since this is a gas appliance.
Dec 31, 2012 | Rheem Water Heaters
Pilot light on my rheem water heater goes out frequently, model # 22v50f1,about 4-5 years old
There are many reasons why pilot light can go out, from bad thermocouple to low air supply to dirty combustion parts, clogged orifice, low gas pressure, etc.
Copy following link and read information available for troubleshooting pilot outage.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
Jul 25, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Hi, I have an old Atwood gas water heater (model j81 I think) this is a manual unit which we have to light the pilot light on. It will light and we can heat water for a short time only before it goes out...
That is not a model number that sounds familiar. Should be a tag on side of water heater behind cover, outside. If it has the little arm adjustment for temperature on top of gas valve, simply move it over a little to the left to increase water temperature, and try it until temperature is what you are happy with.
I'm assuming when you say it goes out completely that the pilot remains on and water heater re-lights when called for? If you adjust that temperature lever over, and water still doesn't get hot, you need to replace gas control, as thermostat is built in to it.
Dec 07, 2010 | RTO Water Heaters
My heater is not getting hot i can not tell if their is a pilot light or a reset button i don know what to do with the heater it is very different how can i heat my water heater
Reliance makes gas and electric water heaters.
http://www.reliancewaterheaters.com/
Best way to start is to look at label on side of tank.
Label has serial number, model number, plus it will say if heater is gas or electric.
Reliance water heater age is shown in serial number: first digit is letter, second two digits are numbers: for example numbers 02 would be the year 2002.
If water heater is 8-12 years old, it might be time to consider new tank.
Gas water heater has 3 inch metal flue pipe coming out of top of tank.
Gas pilot is probably off.
Relight pilot light: Most gas water heaters today have instructions on side of tank just above gas valve that say how to relight pilot light. Instructions vary by model.
If you have gas water heater that is older, it might be easier to call a plumber.
Electric water heater has panels on front.
Open top panel and push in red reset button.
If you have electric water heater of any age, you can usually fix it yourself same day:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Dec 03, 2010 | RELIANCE ELECTRIC WATER HEATER
I have a rheem fury 50gal gas water heater that will not stay on. I have replaced the thermo couple, it did lite but then went out.
I would like to know how old this heater is. This information can be found on either model or serial numbers.It won't appear obvious but last six numbers will tell you. You have already changed thermo-couple so I would check to see that it's properly centered in pilot flame.When you light it hold pilot button down for two-three mins.while watching thermo-couple.It should be a nice cherry red. If it is and pilot goes out after you release button then you either have another bad thermo-couple or gas valve is bad.If it does not get cherry red at least on tip then you need to reposition thermo-couple and try again. If gas valve is bad and heater is less then six years old valve will be covered under warrenty,however labor won't typically be covered unless you have extened service contract.Hope this helps.Thanks.
Nov 03, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot lighting
1) Open the door on the bottom of the tank to show the burner. 2) Turn the valve to "pilot" and depress. 3) Light the match, (best if you have a candle/grill lighter), and follow the skinny copper tube from the valve to the burner inside (this is called the thermocoupler). At the end of it, you will see the pilot. 4) Once pilot is lit, keep valve depressed for a minute (this warms the thermocoupler, thus sending a signal to the valve saying the pilot is lit). 5) Let go of the pilot button (usually red). 6) If pilot stays on, put the door(s) back on and turn the valve to "on". You will hear/see the gas ignite when complete. Good luck!
Dec 28, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
No hot water
If the pilot light stays on, the thermocouple and pilot flame are good. If you turn the control to "on" and turn up the thermostatic control knob to call for heating and get nothing else then the control (gas valve, thermostatic control) is bad. The control can be replaced - they are mostly generic except for gas type - but they are not cheap and if the control is bad the tank is probably not far behind (changing the control could cause it to leak). Unless the water heater is less than 3-5 years old, replace the whole thing!
Please rate my answer!
Mar 18, 2009 | Bosch Water Heaters
Heating & Cooling Logo
147 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
