Question about Hoover F7220900 SteamVac V2 Upright Vacuum
Question about broken shaft
Oh you can email the pic to me at abeburrell@yahoo.com. That little piece of the shaft is being very stubborn. It looks like it twisted in half so when I try to get it out, the corner of the shaft catches on the white part of the turbine. I will try to use something straight and sharp to see if I can work it free and then let you know. Thanks for the help.
    President:
  • 1,673 Answers
Ok, I just sent you that picture to your email, hope it will help.
Posted on Jun 09, 2008
The brushbar on my model 17 didn't work. I found the micro switch next to the main motor wasn't making. There is a plastic piece that presses the lever of the micro switch to energize the brushbar...
I'm sorry to hear you're having difficulties with your DC17. If you haven't already got in contact with us directly, I'd encourage you to do so. One of our experts will be happy to recommend the best course of action. You can call us free on 1866MYDYSON - or if you email your details to askdysonUS@dyson.com, someone will be in contact as soon as possible. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Sep 05, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
I removed the broken fan inside, dont remember how to put it back together. any diagrams on the web?
Hi, i forgot i had this file saved. found it back in 2009 when my first one broke down. it is a pdf file complete with pics. and a parts list. this will get you going. i picked up a dime and my impeller smashed into 100 or so pieces. where did you find the part?? please let me know..
i just tried to copy and paste it, that does not work. not sure how to put it on here. it is just a saved file, no link.. if you want to post an email, i will send it. otherwise i will try and figure it out when i get some time. thanks
Dec 05, 2010 | Halo UVST Bagged Upright Vacuum
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Right wheel slips off on Kirby Gsix . How do I fix it?
The shaft is held onto the machine with two little metal pieces on the bottom of the Kirby. They are held on with screws. The rear wheels are held onto the shaft with a little tiny "c" clip.
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
Replacement belt sliding over and smelling v. hot
try taking a small locking washer and push it on the shaft with a pair of needle plyier
May 08, 2009 | Vacuums
Pics of the wiring diaphrams
Ok, I just sent you the diagram to your email.
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Motor shaft/Brush pulley
It cant be repaired you have to order a new pump @http://www.vacuums24x7.com/bistclpa.html
Bi-010-7185 $23.99 or bring it in for repair.
Has anyone tried liquid steel filler?
Mar 19, 2008 | Bissell 8910 ProHeat Clear View Upright...
Broken piece
You will have to replace the brush roll, part #60844-5, belt # 61120B. You should be able to get them from a repair shop, get the right one or it won't work right. You maybe able to go eureka.com and order direct.
Mar 01, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
KIRBY G4 FAN ASSEMBLY ORDER
First put the gasket on the spacer, thin end to to out, push it down all the way on the motor shaft, then put the nylon washer on, then the fan, metal washer and then the pulley, just snug it, (don't tighten too much just beyond hand tightening). Put the casing, top and handle back on.
Feb 01, 2008 | Vacuums
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
19 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
