Question about Brother LS-1217 Mechanical Sewing Machine
About my needle thread tension know
My grandson streched out the wire to the needle thread tension knob and I am trying to order a new knob. I have taken the machine apart and have the knob out. I have a Brother LS 1217 . Thank you in advance for your help.
Sincerely,
Susan
  • Anonymous Mar 12, 2014
    the bobbin tension is off and I can't find the tension screw for the bobbin
  • Brother Master
  • 1,388 Answers
If you contact you local Brother retailer and explain the problem and give your model number they ought to be able to order a replacement which you can install yourself, or, probably more prudent, ask them if they will do it and also check for any other associated "modifications" made by the little fellow.
USA Dealer Search
or.......There ought to be one similar in your home country
Posted on Jun 09, 2008
While sewing I broke the needle, after changing to new needle, the tension knob will not permit the thread to go through. I have a white machine 622. How do I get it to release or lessen the tension?
ALWAYS RAISE the presser foot to release the tension disk. Do this when cleaning between the tension disks and when threading the machine. It also helps to loosen the tension disk all the way.
Nov 18, 2016 | Sewing Machines
The tension knob will not turn below four. The thread keeps breaking.
check that the thread is between the plates and not behind them
thread breaking can be from wrong size needle eye, poor quality thread , old thread and needle/ eye timing
Dec 11, 2015 | Singer Merritt 8734
Why can't I get a good stitch?
bad stitches can be attributed to incorrect thread tensions
if the thread is bunching under the material -tighten the needle thread tension
if it is missing threads or not pulling the top thread up properly adjust the bobbin thread as it may be too tight
Sep 25, 2015 | Sewing Machines
My top thread frays and then breaks while I am quilting with my 1600p dbx.
change to a new needle
check to make sure thread has no knots or even change the thread spool
check the top thread tension it sound like it's to tight
check the needle plate for burrs
check around the tension knob for loose pieces of thread or lint
use a can of air that you'd use on a computer keyboard on the tension knob & if you don't have the can of air use unwaxed dental floss but make sure to write down the setting it was on before cleaning.
& also under the needle plate area in case there is loose threads or lint & also the bobbin area
Aug 11, 2011 | Janome 1600P-DB Mechanical Sewing Machine
Singer 2517c -I need Threading instructions please. Also the top thread is loose -how do I fix that
Lift the needle to the highest point by turning the handwheel. Lift the pressure foot to release the tension on the system. Place the spool on the spool pin and put the spool cap on to hold the spool firmly.
Next bring the thread to the thread guide and snap it into the guide. Then slide the thread under the guide and through the slot (use one hand). Next lead the thread down on the right of the tension knob and up on the left. This puts the thread in the tension discs. Next slip the thread into the take up lever. (Bring the thread to the top of the lever and back towards the machine. Then slide the thread into the slot on the take up lever and then back towards you.
Next lead the thread through the next pair of guides. One is on the machine below the take up lever; the other is attached to the needle holder.
Finally thread the needles from front to back.
First check if there is a slight drag on the upper thread when you pull it through the machine (pulling it under the foot of the machine). Move the tension knob to the right to increase the tension. When you stitch a test piece, your top thread is visible on the bottom of your sewing thread, rotate the tension knob to the right by half a turn (get the dot closer to a higher number).
If there is no change in the tension as you turn the knob, take the machine for service. The springs in the tension system may need to be replaced.
The manual is available from Singer here: http://www.singerco.com/accessories/manuals.html . Enter only the 2517 model (leave off the c). A pdf is available for free; there is also an option to order a hard copy. A picture of the threading route is on page 28 of the pdf (page 26 as the manual is numbered).
I hope this helps.
May 12, 2011 | Singer 2517 Mechanical Sewing Machine
I bought a White Family Rotary sewing machine made in 1909. While cleaning it up, I unscrewed part of the tension assembly on the face plate not knowing that these can be very difficult to get back...
  • Set up your sewing machine on a table with good lighting available. Plug in the electrical cord. Insert a new needle into the shaft on the needle bar and tighten the thumb screw to secure the needle. The needle bar is the area on the shaft where the assembly for the needle thumb screw is located.
  • Step 2 Thread your sewing machine according to the manufacturer's directions. This requires slipping the thread through various retaining and tensioning loops to allow for the proper drag while sewing. There is usually one loop at the top to go through first, then a second above the thread tension knob. Bring the thread into the tension knob area and pick up the loop of the tension wire. Bring the thread back to the next upper thread loop and then down to the needle bar where you thread the needle.
  • Step 3 Wind a bobbin with the thread that you intend to use. You may have to partially unthread your machine to do this. Make sure there is tension on the thread while you are winding it so that the thread winds properly. Insert the bobbin in the bobbin case and place it in the shuttle race then draw up the thread with the needle thread to prepare to sew. The shuttle race is located in the lower body of the machine under where the needle enters the throat plate.
  • Step 4 Cut a scrap of fabric from the fabric you intend to use for this project, at least 12 inches long and 4 inches wide. Double the thickness of your scrap by folding it in half lengthwise. Insert your scrap under the sewing foot and lower the foot into position. Sew a seam approximately 6 inches long then remove the scrap to check the stitches. If the stitches are loose on the bottom, adjust the tension knob to a higher number for more tension. This is done by turning the knob so that the indicator mark moves to a higher number. If the threads are loose on the top you will need to make the opposite maneuver.
  • Step 5 Sew more seams on your scrap, stopping to check your thread tension for your stitches until you have stitches on top and on bottom with no discernible looseness.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Jun 17, 2010 | White Sewing Sewing Machines
    JUKI MO 134 SERGER
    How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
    Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
    The thread tension knob came off. I don't know in
    The tension knob came off and I need instruction on the order in which it goes back together.
    Oct 29, 2009 | White Sewing 1409 Mechanical Sewing...
    Mylock 134d janome
    make sure the needle is pushed in properly.
    Jun 24, 2008 | Janome MyLock 634D Mechanical Sewing...
    Threading a husqvarna huskylock 1001L serger
    Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
    1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
    Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
    Threading order:
    1. Upper looper thread (green)
    2. Lower looper thread (blue)
    3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
    4. Right needle thread (red)
    5. Left needle thread or double chain needle thread (yellow)
    Caution!
    Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
    Upper looper (green) sequence:
    1. Thread holder (silver triangle openings attached to thread holder stand)
    2. Thread guide (flat silver clips just behind thread tension disc)
    3. Thread tension disc (circular knobs with numbers for tension setting)
    4. Pull thread around upper looper guide and upper looper
    5. Pull thread into hole of upper looper
    Lower looper (blue)
    Repeat 1, 2, 3.
    4. Pull thread around guide (see color coded chart inside front serger cover).
    Easy threading mechanism (for lower looper)
    1. Pull out the lower looper threading lever
    2. Thread the lower looper and position the thread on hook of the lower looper
    threading lever.
    3. Push the lower looper threading lever back to its basic position while
    holding the end of the thread.
    Caution:
    When returning the lower looper threading lever, always make sure that the two
    blue triangle marks (directional arrows) meet each other.
    Left needle thread (yellow)
    Important: Thread the needles after threading of lower looper and upper looper.
    First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
    Jun 24, 2008 | Sewing Machines
    Brother LS-1217 Mechanical Sewing Machine Logo
    104 people viewed this question
    Top Brother Sewing Machines Experts
    Bargain Box
    Bargain Box
    Irene Tulloch
    Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
