Question about Pioneer Televison & Video
Have a pioneer pdp5040hd television and just baught a video game. The tv is mounted to the wall. Where excatly is the audio video connection located on the back?
  • 47 Answers
Usually you can get to them from the bottom of the unit, but still may not be enough clearance.
You may want to simply get a switching device and attach to one of the other devices ( dvd or cable box )  Check with MCMelectronics.com for a/v switchers
Posted on Jun 08, 2008
N64 powers up but no video or sound
Important Note:
We highly recommend you review the following precautions before you set up and operate your Nintendo system:
Important Safety Warnings & Precautions
Hardware Precautions / Maintenance
Game Pak Precautions / Maintenance
Precautions Concerning TV Screen Damage (Image Retention)
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo A/V cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting the each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo A/V cable into the "multi-out" connector on the back of the Control Deck.
After system is connected to the TV:
Insert Game Pak fully into the Control Deck.
Plug the Controller(s) into the front of the system using the left most port for Player 1.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It's often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You're ready to play!
If after following these directions completely you are not able to view the game, try our Troubleshooting Tips.
Jan 04, 2013 | Nintendo 64 Console
Dropped in snow green light comes on but nothing else does
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Jan 24, 2011 | Nintendo DS Lite Console
It is sync and i can see the status on the upper left corner of tv but cant get it to function?
Please follow these same steps for your SP3 The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
I formatted my wii and it says must have a update from the shop channel if necessary, add wii points
Jan 22, 2011 | Nintendo Wii Console
Who to do set up for wii game
  1. The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well.
    • Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom.
    • Look for inputs marked Audio and Video IN.
    • Do NOT connect your system to anything marked OUT.
    • Don't see these inputs on your TV? Click here.
    1. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console
  2. Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console.
  3. Insert the AC plug into a 120V AC wall outlet
  1. Plug the transformer into the wall outlet.
Jan 12, 2011 | Fisher PC-25R20 25" TV
Where/what do I buy to mount my tv on the wall?
You can buy almost any wall mount for it, just be sure of 2 or 3 things... 1st the location, you have to screw some rather large bolts into the wooden studs in the wall so check where it will be located... 2nd weight and size... You want a mount that will be able to hold up the weigh of the TV, usually the size will be between 32" to 40" (various mount sizes) Just make sure the size 37" is between the size lengths... and 3rd that it has a "tilt" adjustment... due to the placement of the TV you might get either reflection off of a light source or you may need to change the angle so that you can see it better on the wall... Hope this helps out and if in doubt be sure to ask someone at the store you buy your equipment (TV, Audio, Games, etc)...
Mar 27, 2009 | Dynex DX-LCD37 TV
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
Screen goes blank, audio still works
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Oct 26, 2008 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Pioneer wall mount
There are only two solutions to your problem. The first is to use another location. The second one is to take out the section of drywall and put horizontal braces between wall studs where you want to mount the tv. Sorry there isn't a simple solution.
Mar 03, 2008 | Mitsubishi VS-60601 60" Rear Projection...
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
