Question about RCA TruFlat 27F520T 27" TV
Unusable signal prompt on video input
I am trying to use my ps3 on the truflat 27" screen tv and keep getting a unusable signal. Why is this?
  • 1 more comment
  • speakingfree Jun 12, 2008
    This did not work. I am going to get rid of the tv.
  • hckyspieler5 Sep 08, 2008
    Just came to college with my PS3 and tried to hook up to my roommates RCA TruFlat TV via the red, yellow and white cables. Same set up as my house. all i am getting on his TV is a gray screen saying "unusable signal"
  • Anonymous Mar 13, 2014
    screen shows unusable signal when using vcr
  • 48 Answers
Be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Posted on Mar 14, 2009
  • Bob F Mar 14, 2009
    sorry for long initial solution post, sounds like a video input seletion poblem on the tv. I get unuseable signal when I'm on tuner or component inputs selected but with no device attached to specific component or coax connection. cycle thru video inputs--use remote's Input button. Or, try hitting channel + to get past all the cable channels--then it'll start changing the input with channel+ panel button. RCA yellow for video is going to be something like Video 1, video two, side, or front. definitely NOT Component. Also, tough to do without a display, but the PS3 must be set for A/V cable (rca/svideo) selection on the settings...Video section. If this tv has component inputs (Red/Blue/Green aka Y,pb,pr), get a PS2 or Ps3 Component output cable!!! Can be found for $10-20 new, cheaper even used or clearance--HDTV via component cable--maybe not HDMI at 1080P, but VERY impressive at 720p or 1080i or even 540p--it's how a PS3 NEEDS to be seen. I didn't even know some of the detail I was missing when only using SVID/RCA--you'll love it.
  • 85 Answers
Posted on Jun 12, 2008
What does it mean when my tv says unusable signal
The format of signal you feeds to it cannot be processed by its internal circuits.
Jan 09, 2013 | RCA TruFlat 27F520T 27" TV
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
How can i change the video input on my rca truflat tv 27F520T without the remote
As there is no Menu button on its front panel. you can't select inputs to this TV without a remote control.
Jun 05, 2012 | RCA TruFlat 27F520T 27" TV
No channels
Does the set have any audio/video jacks for input?
Apr 03, 2012 | RCA TruFlat 27F520T 27" TV
How do I get the input to work for the PS3 on a a RCA truflat tv, the cords are connected properly, we tried all the inputs. now what?
If the PS3 was hooked up to another TV, perhaps with the HDMI, the PS3 needs to be reset. With the PS3 off, press and hold the Power button for approx. 10-15 seconds until it beeps again. This should provide picture/sound through the A/V cable. Hope this helps.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
Unusable Signal Message
I can;t keep my DISH satillite to turn on. when I turn the tv on and hook up the cales i get unusable signal and blue screen
May 21, 2010 | RCA TruFlat 27F520T 27" TV
Unusable signal
Usually need a second receiver. Cannot just split signal. With some cable providers you can split the cable before it hits the cable box for basic cable channels.
Suggest contacting Cable Company if does not work.
Mar 23, 2008 | RCA TruFlat 27F520T 27" TV
No picture with vhs
Don't pass the video sample through the Onkio.. Use a second single RCA patch cord to go from vcr to TV... Use the same yellow out on the vcr that you're using now and send it directly to the yellow video input you're using on the TV..
Hope that's clear - I'm getting tired...
Dec 02, 2007 | RCA TruFlat 27F520T 27" TV
RCA Truflat no picture
problem is in your tv. this is due to blue catode circuit failure. please get it check 1 loose contact in blue cathode crt. 2 loose in crt base. 3 supply to blue video ckt.& transistor itself 4 check blue video ckt components. 5 check blue signal coming to blue video. 6 connector loose. 7 processor ic.
Sep 28, 2007 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
1,837 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
