Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson won't run
My dyson runs for a few minutes then it dies. it will usually come back on the next day, but then again only runs for a few minutes and dies. what could be the problem?
  • ngzap Jun 26, 2008
    I have the same problem. I've removed all hoses to check for blockages and I've cleaned the pre-motor filter several times. Any other suggestions?
    Thanks,
    Missing my dyson!
  • 46 Answers
Could be overheating. I know that there is the cylinder where the dust goes, but after that there is a foam filter between that and the actual engine. You will need to make sure its cleaned out.
im not 100% familiar with your model, but my one had alot of advertisement with it when i bought it telling me that every 6 months i needed to take this foam pad out, wash it out one way, then the other, then leave to dry for 24 hrs.
Remove the cylinder and work backwads towards the engine, there may even be a little sticker to tell you where it is, and how to remove it (seriously i have 2 stickers on my vacuum)
Posted on Jun 18, 2008
I bought a cordless Dyson, three days ago. I have charged it three times. It states that this model has a twenty minute running time. This one runs less than 10 minutes. JU6-US-HEA1415A
If after a few more discharge, charge cycles unit still underperforms then return for exchange or money back. Newer batteries have to be "exercised" a tad before they perform up to specs. And if they say 20 minutes, then hold them to it!!!!!!!!!!!!!!
Nov 28, 2016 | Vacuums
Why does my dyson only run for a few minutes after charging
possibly the battery is dying OLD AGE and you need a new one check with the manufacturer Dyson vacuum cleaners fans heaters accessories spares official site
Sep 05, 2016 | Dyson Vacuums
Dyson animal ball
You need to call Dyson. We had the same problem with 2 of them! When we installed new carpet, the newer machine was literally impossible to push. Long story short, they advised us to remove all of the gaskets on both heads. Their better now, but I question the quality of a product which has to have parts removed in order to function. Also, I suspect that those gaskets kept dust from being introduced into the interior of my home. I doubt that I'll ever own another when these 2 die. . .
Jul 26, 2017 | Vacuums
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
Works intermittenly
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dies after a few minutes of vacuuming
The thermal cut-off in your machine is activating - this indicates that you have a blockage or a clog in the machine. The machine will turn itself off so that the motor doesn't overheat - the machine will cool off and you'll be able to turn it on after 30 mins to an hour.
Call the Dyson Helpline for a thorough blockage check - they know what they are doing.
Jun 15, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
110 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
