Question about Samsung VP-D361 Mini DV Digital Camcorder
Scf-703 vhs camcorder samsung
I charged the battery to 13.4v and put in the tape in. there is blinking red l.e.d on and shuts off. any ideas?? good vhs tape too.
    Problem Solver:
  • 6 Answers
Ineed to downlaod digital cam VP-D361 pal drives
Posted on Jun 23, 2008
Blinking red light won't record
Hi, You might have a tape in the VCR that has the 'record tab' broken-out, prohibiting recording. IF you want to record, eject the tape and put a piece of scotch tape over the missing square tab on the bottom corner of the VHS tape. Good luck and let me know if that works for you.
Sep 09, 2014 | Sansui VHF6010 VHS VCR
Redl ight blinking but battery(ies) fully charged
Flashing red could indicate dew sensor (camera has condensation/ damp) or other fault. See your manual Troubleshooting section.
Mar 08, 2012 | Video Cameras
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Tape end camcorder
Have you tried different VHS tapes? If your VHS tape is too far rewound or at the very end your camcorder will display this problem. In a different VHS machine make sur the tape is rewound and then play the tape about a minute and then try it in the VCR.
If this doesn't work then there is a problem with the tape end sensors in your VCR.
Oct 04, 2008 | Video Cameras
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Playback *stops* on tapes where I used Aux input to record
It could be that.. you generally want a timebase corrector to properly record from analog tape to some other medium. But maybe not. Most tape-based devices also include a tension sensor, to detect the end-of-tape. If you're using tapes that are too old, cheap, etc. it could be that you're seeing this triggered.
I recommend trying the same VHS recording with a good quality, fresh tape. If it's still kicking off, you at least know it's due to the camcorder having issues with sync or something on the tape. If it works, blame the old tapes.
It's probably camcorder dependent, but I have done tape restorations using Digital8 and DV equipment, and have never known a camcorder to cut itself off due to dropouts or other problems on the tape -- mine just play through. So I think it's at least possible that it's just the tape.
Jan 20, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
JVC GR-AXM18U Compact VHS Camcorder
perhaps you should turn off the camcorder, remove the battery, wait a minute, and then put it back in.
Jan 11, 2008 | Video Cameras
Camcorder is not recording
the capstan motor of the camera is not running that why the power display is blinking and when you eject the tape there a portion of the ribbon that left..it is a poor connection of the capstan motor to the main board of the camera....
Dec 13, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
Panasonic PV-L557D vhs-c camcorder wont stay on
it probably goes into a shutdown mode because of those dreaded pan capacitors!!. These are small surface mounted capacitors that dont just go bad in almost all camcorders but they will leak and be very very corrosive to the Printed curcuit board and eat up the pc traces!! The onlt way to see if this is the problem is to have the unit looked at by a quilifyed camcorder specialist and see if that is the problem? Good luck
May 11, 2006 | Panasonic PV-L557 VHS-C Analog Camcorder
Why does the VCR ejects my tape?
The VHS PlayPak adaptor uses 1 AA battery. When you place your VHS-C tape into the adaptor and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink-wrap has been removed from the battery.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Samsung VP-D361 Mini DV Digital Camcorder Logo
220 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
