Question about Canon NP 6545 Copier
Canon copier np 6545
Get and error message E540 (Switch the power on and off again)
  • 86 Answers
E540 is a sorter/collator problem
You can unplug the sorter and move it away from your copier then swith off then on again and the copier will work and you can still sort via the document feeder.
here is the error code disription...
E540
Cause..
• Bin shift motor (fails to rotate)
Discription....
• The operation does not end within a
specific period after the motor drive
signal has been generated.
• Clock signals from the clock sensor
of the motor are absent for a
specific period.
• The input signal from the lead cam
position sensor does not change for
a specific period.
Posted on Jun 09, 2008
HAS CODE E532 AND MESSAGE TO TURN OFF AND BACK ON
E532-1 Stapler guide bar motor E532-2 Stapler swing motor E540-3 Bin shift motor
Apr 01, 2010 | Canon NP 6545 Copier
Canon NP 6545 error e210
This code refer to expo unit.The home position sensor possble defected.To reset press the service mode switch sw850 and wait 3 sec,or opem close the front door.
Aug 12, 2009 | Canon NP 6545 Copier
NP 6545 Copier - Error Code E401
error code E401...DF paper feed motor lock...check the motor of your DF...try to turn off the machine and unplug the communication cable from DF to the machine and turn on the machine again...
Mar 16, 2009 | Canon NP 6545 Copier
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
E001
That is a fuser realted issue. Not warming up properly.
Most likely a defective fuser. The over heat has opened, the heat element has gone bad.
Fuser more then likely needs replaced
Jan 15, 2008 | Canon NP 6545 Copier
Error - E401
e401 on a 6545 is the RDF (reversing doc feeder) pick up motor or pick up sensor problem. Does the rdf attempt to pick up the original or do you get the error as soon as you press start? Are you aware of how to remove all the rdf covers? The pick up motor has a timing wheel & sensor that need to be periodically cleaned.
Jan 22, 2007 | Canon NP 6545 Copier
Canon NP 6545 Copier Logo
263 people viewed this question
old marine
old marine
