Question about Amana Heating & Cooling
We need a wiring diagram for an AMANA furnace, GHE75-3.5. Can you help us? Thanks.
  • 828 Answers
Http://www.amana-hac.com/ This site has a means of contacting them to get information under products, and heating.
Posted on Jun 08, 2008
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Amana furnace. How do I replace a 4-wire transformer with a 6-wire?
The new transformer should have a description on the side or top. Like: Com, Color, Volt. For example, say you have `120 volts, com-white, black wire - 120 Volts. Make sure you carefully read which wires to use or have a tech come out.
Nov 12, 2015 | Heating & Cooling
Amana model gmh95070
Don't need the blue wire is common for the ac condsor unit what t-stat is it honeywell 4000 6000 8000 or one of rth models there is many t-stats as far as you saying fan stayes on check the auto / on section of the t-stst main wirers are RH/R-power W-heating Y-coolin G-fan
Mar 14, 2014 | Goodman Heating & Cooling
HELP!! New install of GMUH75-E3A - Main blower starts immediately on power up/ thermostat turn on. Burner never turns on/ignites. AC power is wired correctly and gas supply is connected. Switch is in the...
You need to find out if the problem is in the T-stat, T-stat wire or in the furnace you can do this in a few easy steps
Step 1- Unwire the low voltage from the furnace. Then turn the power back on and see if the blower comes on if it does then the problem is in the furnace and you will need to troubleshoot the furnace (see bottom of page for troubleshooting furnace) if it does not then proceed to step 2
Step 2- Wire the low voltage back up to the furnace (follow the wiring diagram below). And unwire the T-stat, make sure that no wires are touching each other, then turn the power back on to the furnace, if the blower starts then you have a short in the T-stat wire and you will need to pull a new wire. If it does not then proceed to step 3
Step 3- Turn the power back off at the furnace and wire the T-stat back up (follow the wiring diagram below). Turn the T-stat to auto heat 90 if the heat does not start but the blower just runs then you need to replace the T-stat.
http://www.hvac-for-beginners.com/furnace-troubleshooting.html
wiring diagram
Nov 24, 2010 | Comfort-Aire Heating & Cooling
Amana PGD60C1152E no heat
Your thermostat Function 0170 must be set to "1" for Single Stage Heat/Cool. Function 0180 must be set for "0" for Heating Fan Control. Function 0240 must be set for "5" for the Heating Cycle Rate for your <90% Gas Furnace. If you have already done these steps or if, after doing these steps, you continue to experience a problem, you problem could be with your Gas Furnace. I'm including some links for information on your system and thermostat that include wiring diagrams.
http://johnstonesupply9.com/TechDocs/Amana/Package%20Units%20Gas-Electric/PGD%20Pkg%20Gas%20Ele/PGD%20Tech%20Info.pdf
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2206EF.pdf
Mar 06, 2010 | Amana Haier AP125HD Air Conditioner
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
My Amana Gas Fired Air Furnace (80) failed to come on with warm air. Blower works but cold air only? Is there an obvious problem here?
first, clean the flame sensor, does the draft motor come on?  could be ignition control board failure
Nov 15, 2008 | Amana Heating & Cooling
We are look at purchasing a 95% Amana AMV9 furnace. What is the pro and cons on this unit furnace. Thanks for your help. Judy
the best furnace you can buy is a two-stage furnace with a variable speed blower, the most effecient furnace you can buy is the 95% one. the most important thing is the technician installing it. there is a very advanced setup configuration that needs to be followed depending on your outside unit, your ductwork, and the living environment. find a NATE certified dealer. also, look for a Lennox Premier Dealer, and an American Standard Customer Care dealer. you can find them by going to Lennox.com and AmericanStandardAir.com
Nov 12, 2008 | Amana Heating & Cooling
How to set dip switches in highest point for multi speed blower. Have gas furnace (amana) and heatpump(amana) both 4 ton cap. My hp keeps cycling and asume is the lack of airflow.
Yes, it could very well be the lack of air flow, how to set the dip switches, need more info on the setup or diagram or instructions, write me at wbwill@sbcglobal.net, I will try to help you
Sep 16, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
542 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
