Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
Toshiba 46h84 green crt
I'm fairly sure my green crt is bad. Do you know where I can get one? Toshiba has discontinued them and I.m having a tough time finding one.
Thanks,
ktrach
  • ktrach Jun 12, 2008
    I have emailed them twice now and have had no response.
  • Toshiba Master
  • 8,617 Answers
I would leave an email at the following link with your model number and what youre needing, as they have a large supply of hard to find CRTs and circuit boards. They will respond quickly to your request.
http://servicemanuals.vstore.ca/
Posted on Jun 08, 2008
  • Sonny Berry
    Sonny Berry Jun 12, 2008
    I am one of their support techs. Did you click on the contact link on the lower left side of their home page? As the girls in the office havent recieved any emails for toshiba tubes.I would try again, as tornados where rolling through the other day and power was out for a while.
How to replace procector lamp in model 46h84 toshiba
Projection TV sets have three tubes - red - blue - green and they don't fail often...they are located inside the tv DLP TV sets use a single bulb and a clot wheel to make the three colors display...DLP bulbs do fail about every two years and will need o be replaced. Replacements can be found at www.TvRepairKits.com and its located behind a small door on the rear of the tv.
May 19, 2013 | Toshiba 46H84 46" Rear Projection...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Green CRT Bulb is shorting out on 46H84 Toshiba. Repairman says no replacement bulbs are available.
Thanks I ordered the part # required to solve the problem through the links you provided.
Sep 07, 2009 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 Blue CRT Misaligned
The problem is you convergence IC's. STK392-110. If you are not experienced I would contact a tech to do this work. Repair costs should be 200-400 depending where you live.
Dec 08, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46h84 rear projection shutting down
I have a Toshiba 46h84 with similar problem that needs a new green crt. Mine does not have a cooling fan. I don't know if having a cooling fan would help the problem, but mine didn't come with one. There are rear projection TV's that have bulbs in them that require a fan. This particular model uses a red, a green, and a blue crt to generate the picture and probably doesn't need one.
May 19, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46 in
the tube will be around 400.00 and then the repair tech will want maybe 150 to install. Try this link they may be able to get you one some what cheaper and give free tech support so you could install it yourself.
Apr 29, 2008 | Toshiba 46H84 46" Rear Projection...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
SCreen turns red then shuts off
The 46H84 has 3 CRTs instead of a lamp. Red, Green and Blue. Your red CRT is shorting out shutting down the set.Here is how you test that theory. Remove the speaker grille, there will be an access panel behind the grille remove that and you will see the CRTs red is usually on the left. hit the power momentarally to locate which tube is red. then power down and unplug the power cord. Carefully remove the tubes Circuit board. ( you may have to carefully slice the glob of silicone applied at the factory to get the circuit board off) Once you have the circuit board off the Red CRT make sure it isnt touching anything and try powering up the set. If the set stays on and the other 2 CRTs light up. That tells you the RED crt is shorted and thats whats shutting your set down. Let me know if I can assist you further.
Mar 25, 2008 | Toshiba 46H84 46" Rear Projection...
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
