Dear You can download the driver from the canon web site. You can print only through USB port. However if the machine has N/W card installed then you can use the color scanning facility and you have to download the scan gear software from that site.
Hello
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
otherwise
This code also for Heater Coil Fault.
Replace the Fixing Element Coil.
Hope this helps
CANON IR 6050 IS AN ANALOG COPIER.
CANON IR 400 IS A DIGITAL COPIER.IR 400 IS SINGLE SCAN & MULTI PRINTS ,STACKLESS DUPLEX & ITS CAN BE USE PRINTER & FAX ALSO.
