Question about Pioneer GPS AVIC-X1 car radio
Pairing with a nokia n73
Can anyone help me, the bluetooth on my nokia searches and find my avic-x1 but the phone asks for a code...does anyone know what it is??
  • Anonymous Mar 15, 2014
    How to pair pioneer avic z140 Bluetooth to cell phone?
Code should be 0000
Posted on Sep 01, 2008
How to do "master reset"for pioneer?
Posted on Jul 28, 2008
Bluetooth pairing
its so simple just pair your bluetooth on your laptop to your mobile when its asks for code just press number 1 and it will asks again on your mobile and press gain number 1....its done..
Apr 27, 2013 | Nokia 6120 classic Cellular Phone
Cant connect vwith my nokia e71 phone
hello,please kindly put your nokia bluetooth on and also power the bluetooth headset on so as to pair them. 1.search the bluetooth headset with your nokia then you might be asked to enter a code,you then enter 0000 and ok it. 2.when the pairing is complete your bluetooth headset displays and blinks red light.
wish you good luck.
take care.
Jul 19, 2011 | Nokia BH-503 Bluetooth Headset
E52 i want pair with my pc i do not know what is the pair password how to do it please clear
Hi, Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Feb 13, 2011 | Nokia BH-104 Bluetooth Headset
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
N97 paring code
It is a passkey to allow further communication between both devices. It is normally entered just once. Already paired devices communicate with each other, provided that their bluetooth stacks are turned on. You can enter any number you want as pairing code, provided that it is the same one on both your phone and your computer. By the way, the most commonly used code for bluetooth pairing is '0000' (four zeros).
Hope it is the kind of information you were looking for.
Cheers! Carlos
May 04, 2010 | Nokia N97 Cell Phone
Ive just braught car car with a 3200 ls already in the car, ive erased all old phone that have ben used on it but i dont know how to link my nokia n95 to it, can anyone help me ?
2 ways of doing this. Go in to the bluetooth menu of your phone and search for the device, it will come up parrot 3200ls select this and it will give you a pin on the screen enter pin in the phone when asked and hay presto! you will have to send over the contacts tho, you do this by going into contacts then options, mark, mark all, send, via bluetooth, select the parrot, and it will send them all over. The other way is if it doesnt give you a code on the screen when pairing, go in to settings, pair with phone, then other phone, pin will come up. search from phone and then select.
Nov 29, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
How to connect LG cookie with Nokia Bluetooth BH 101
Put your Nokia Bluetooth BH 101 into pairing mode - this is normally done by pressing and holding the power key for several seconds. An alternate bleep will sound with a flash light to indicate that you are in pairing mode.
Now using your Cookie, press Menu > Settings > Bluetooth > Search
Your Cookie will find the Nokia BH101 bluetooth headset and then it will ask for a pass code. This is usually four zeros (0000).
You should now be connected!
Apr 10, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Bluetooth help
turn on bluetooth in both the phones
in anyone of the phone try searching for new devices.
it may ask some code for pairing of both the devices.
after giving the code ,both the phones ll be enabled to send and receive the files in both o them..
Jun 16, 2008 | Cell Phones
N73 not pairing with visorlite
here's the manufacturer's website where you can download the manual (it is also marketed as Supertooth Light)
http://www.supertooth.net/down_light.html
Mar 13, 2008 | Nokia 6300 Cellular Phone
Pioneer GPS AVIC-X1 car radio Logo
258 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
