Question about Maytag MEW6527DDS Electric Single Oven
Installing new keypad
Installed new keypad and the clock comes on and the buttons beep, but they don't do anything.
  • 72 Answers
Try reconnecting the ribbon connectors to the control board
Posted on Jun 16, 2009
My husband just installed a kenmore single in wall oven and it is screaming F1 at us what does that mean?
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2010 | Kenmore Ovens
Oven beeps with f7 code , replaced display pcb . oven still beeps replaced front touch pad , now cooling fan comes on and after a while oven beeps with no error code . and blower fan button does not work ,...
hello,
(indication of problem)
This error code on a oven indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.comappliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this information helps you.
thank you for using fixya.
Oct 03, 2010 | Jenn-Air Ovens
I have a Kenmore Wall electric oven unit that the heat element at the top is working only and F2 is what comes up and continues to beep. The heat is extreme. WE are wondering if we should just get a new...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have to turm the oven off at the braker box. it comes on by itself. when I turn it on to cook it will not stay on gos off and beeps. Shows C7 or F7
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
Jun 15, 2010 | GE JKP20 Electric Single Oven
I am getting an F7 error signal and a constant beeping that will not go off no matter what I do. I even turned the circuit breaker off ... but the beeping and error signal persists. What should I do?
Hello there
Normally when you have this errr code it isreferring to the keypad or touch pad that is failing or has failed and needs to be replaced
Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button
Jun 05, 2010 | Ovens
F1 is popping up on my digital display and a beeping noise comes along with it. What does that mean and how do I get it to stop?
Your F1 error is
: indicating an electronic control malfunction
: (a $250 part) or a control panel (a $60
: part)? Usually if the symptoms stop with the touchpad disconnected from the clock, that touchpad is often the cause. If the error continues even with the touchpad disconnected, the clock itself is usually at fault and will need to be replaced to correct the problem. On some models it is not possible to disconnect the two in which case the electronic control/clock would have to be replaced regardless.
There is a tool that allows testing of the touchpad (on models where they're separate parts) but is kind of expensive for a homeowner to purchase them self. If you contact a technician so equipped, they should be able to test the touchpad before replacing any parts.
BTW. On most models, the control keypad is only sold along with the whole control panel (without the electronic control) but on some models the keypad linked below can be used to repair the one on the original control panel.
Apr 19, 2010 | Magic Chef 9122 Gas Single Oven
Screen shows F-1 flashing . I had a clock failure previously with a F-7 trouble code . I ordered another from Sears and installed it today . Everything worked OK after the new clock assembly was installed....
We usually see F7 caused by a failure in the keypad (stuck key) and F1 caused by a failure in the control board (clock). This seems opposite to your experience. I would suggest first to power down the oven, unplug the keypad from the control board, power up the oven with the keypad unplugged. Give it some time (may take as much as 30 minutes or so), if no F1 error then problem is likely the keypad. If you still get an F1, then the problem is the control board and you should return it. If you still have trouble post your model number.
Regards,
www.fixyourboard.com
Sep 10, 2009 | GE Ovens
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Our Whirlpool oven started beeping and the code read, E6 F2. We talked to a Whirlpool rep and he told we needed a new touchpad. We ordered a new touch pad and when we hooked it up, the code read E1 F2,...
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#@!
Feb 06, 2009 | Whirlpool RBD305PD Electric Double Oven
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Maytag MEW6527DDS Electric Single Oven Logo
118 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
