Question about Fuji FinePix F20 Digital Camera
Pictures too bright
On the LCD screen, the picture looks just fine, but when it is taken, it is so bright you cannot recognize what is in the picture. This happens even with the flash suppressed.
You sensor could be gone.
if its still under warranty they'll either replace the sensor or give you a new one.
Posted on Aug 29, 2008
LCD Display is Black
the image in the LCD monitor will darken in strong sunlight or bright light. This is normal occurrrence in device CCDs and does not contitute a malfunction. This image will not be recoded when shooting still photos, but it will be recorded wihen shooting movies.Read you owner manual and adjust the MENU, according with your o. manual.Otherwise you must go the repair shop
God bless you
Jul 31, 2012 | Canon Cameras
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
When taking pictures outside the view screen after picture taken appears as a bright burst of white light. Inside picture appear fine. Any ideas?
let me see if i understand. if you llok at the screen it looks ok, but after you take the picture it will record only a white bright image.....
in some cases you can easily fix this by goining into your camera option and restoring default settings. it is the exposure setting .
if you camera still giving you just black white images the light sensor in the machine ahs gone bad, it needs to be replace.
Oct 04, 2009 | Nikon COOLPIX L4 Digital Camera
Picture result is too bright when taken on outdoor condition
change the lcd setting by pressing menu then right arrow. go down to the sun picture and then click the left arrow and put it in the middle. i hope this helps.
Apr 25, 2009 | Canon PowerShot A420 Digital Camera
Can't see picture in frame when taking outside pictures
This is a problem with digital cameras with LCDs. You can make things better by upping the brightness of the screen - this will consume more power though.
Go into the menu (middle button at the back), into 'setup', and then look for 'LCD brightness'.
Apr 17, 2009 | Kodak EasyShare V1073 Digital Camera
The picture we have taken was white/grayish screen- no images..
I got it repaired at canon service center in India for Rs 1900.
Next camera I will insure !
Jan 19, 2009 | Canon PowerShot A460 Digital Camera
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
FD-88, viewing LCD in daylight, too bright
You're not doing anything wrong. Sometimes it's just hard to see to LCD. You could try turning down the brightness, or turning off the backlight, but that doesn't work very well either. There are sun shields for sale. I have a FD-88 also, And so far I've been able to see the screen ok in sunlight. But It's winter in Minnesota so the sun is low in the sky, and I can normally shade the screen with my body. Hope this helps.
Sep 11, 2005 | Sony Mavica MVC-FD88 Digital Camera
Fuji FinePix F20 Digital Camera Logo
60 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
