Question about IdentityGuard Cross-Cut Shredder
Identity Guard Model: SH9210PL
My shredder no longer runs on 'Auto'. It works great on both 'Forward' and 'Reverse' but not at all on 'Auto'.
  • Camellia Phillips Jun 10, 2008
    Ekse,
    I have just gotten off the phone with Staples, the vendor I purchased the shredder from, and they told me I would have to wait for 48 hours before I can see all my purchases for the last year. They can only search for the purchases I made using my Rewards card, which I probably forgot to do.
    However, I didn't want you to think this had been resolved yet, nor did I want you to think I had forgotten about you. I appreciate your patience and I will update you as soon as I know something definitive.
  • 13,433 Answers
Do you have warranty? get it warranty repaired - replaced.
Let me know if you don't have warranty.
Posted on Jun 08, 2008
  • 1 more comment
  • Ekse Jun 08, 2008
    Manufacturer Warranty
    1-year warranty on machine and cutting cylinders
  • Ekse Jun 10, 2008
    Sure, if you don't have warranty and you want to fixed we will most likely have to take it apart and check all the wires and components that they are working. as far as i know there is no public service manual for this product so we would have to in blind and check out everything.
  • Ekse Jun 10, 2008
    but in the end its a quite small and simple device, I'm sure you can do it. let me know how it goes.
Sentinel Pro On Guard shredder just stopped working
Mechanism could be clogged with debris, causing motor overload and thermal shutdown.
Dec 13, 2016 | Shredder Office Equipment & Supplies
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
VF1000MX Shredder: Shredder works briefly in reverse, but won't run f...
Try cleaning the "eyes"....if they get dirty they can act erraticaly...if that dosn't fix it you may have a pcb prob....you can give Royal a call at 1-800-524-0799 for parts information and advice.
May 16, 2010 | Royal VF1000MX Shredder
Shredder doesn't want to shred in forward gear, have to Reverse first then switch it to On/Auto. Have to keep going back & forth between Reverse & On/Auto to get document shredded. Shredder is less...
Shredders became popular when the identity theft thing started happening and to save money they stopped making them with quiet, powerful induction motors and now it's almost impossible to find a consumer model without the poor quality loud motors that don't have enough to power to operate the machine once it's a little dirty. Anyway, unplug it, and you're doing this at your own risk, take the shredder off the trash can or its own waste bin and turn it over. If it's straight cut shredder you will probably be able to see the slot where the shredder paper exits the blade area. If it's a crosscut shredder there might be a door that will close over the blades to cut you from getting cut. Respect that, but open this door, and see if there's bits of paper jammed up around the blades. Wear some protective gloves and use pliers or some kind of tool to dig out the compacted trash, being careful not to damage or bend the blades. Now you should pick up some shredder oil from your local office store, or see link to order. Follow the instructions on the oil, and this will make your shredder run with a lot less stress. This is only a temporary fix however. In a couple weeks or months you will have to do this again. It's all part of owning a paper shredder. If you like it that much, look into buying a nicer model. You totally get what you pay for with a paper shredder.
Shredder Oil: http://www.officedepot.com/a/products/285661/Office-Depot-Brand-Shredder-Oil-4/?cm_mmc=Mercent-_-Google-_-Shredder_Supplies-_-285661&utm_source=Google&utm_medium=CPC&utm_campaign=plusbox-beta&mr:trackingCode=7646DB1A-EC81-DE11-B7F3-0019B9C043EB&mr:referralID=NA
Sep 16, 2009 | Shredder Office Equipment & Supplies
Overheating of identity guard sh9210pl shredder
This is typical... Make sure you lube the unit. Put the special oil on a piece of paper and run through per the instruction manual.
Sep 14, 2009 | Identity Guard 10 Sheet Cross Cut Shredder
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Model: SH9210PL
sensor is dirty. clean the sensor. it is located approx. 3 inches from left side of paper slot, 1 inch below top.
Jun 06, 2008 | IdentityGuard Cross-Cut Shredder
REALLY LOUD
your question should be able to be answered here 1-800-789-1331 I tried to find info on decibels but unlike FELLOWES they don't seem to provide that but try this number and they should be able to help you
Feb 26, 2008 | IdentityGuard Cross-Cut Shredder
IdentityGuard Cross-Cut Shredder Logo
1,268 people viewed this question
Top Identity Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Identity Office Equipment and Supply Expert? Answer questions, earn points and help others
