Question about Nikon D40x Digital Camera
Viewfinder can i use the lcd moniter on back of camera as viewfinder or am i stuck with the tiny eyepiece viewfinder? can't find away to use moniter as view finder.
  • 667 Answers
The shutter remains closed on a DSLR until you take a picture. There is no way to preview an image that does not exist yet.
Being stuck with the tiny viewfinder as earlier cameras had is a good thing. Holding a camera out from your body will give mixed results due to your movements. You will get better results with the traditional method
Posted on Jun 09, 2008
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
View is blurry through eye finder
While looking through the viewfinder, turn the little knob at the upper-right corner of the viewfinder to adjust it.
Refer to the "Adjusting Viewfinder Clarity" subsection of the "Basic Operation" chapter of the manual (page 36 in my copy) for full details.
Dec 21, 2011 | Canon EOS Rebel XSi Digital Camera
I have a fugi fine pix, when using it in bright sun light i cant see anything
Geofchaam,
You could be experiencing one of two issues:
1) You are having a difficulty viewing the image on the back of the camera (not the view finder). This is common on cameras out in the sun, try cupping your spare hand over the screen to cast a shadow on the screen.
2) You cannot view anything in the view finder. Since the view finder has its own tiny LCD display inside of it, it is displaying what image the camera will take if you press the shutter release. I would double check to see if the camera is set correctly for shooting in bright sunlight (check your owners manual, or set the camera to Automatic), and if there is a difference between what you're seeing in the viewfinder, and what images the camera is taking, consider calling Fuji, as it sounds like a hardware issue.
Mar 01, 2011 | Fuji FinePix S5000 Digital Camera
D60 Digital Camera: I put a picture on my view finder as a background ...
What you're describing is a feature called "live view" (or more accurately "live preview"). It enables the user to treat the LCD like a viewfinder to compose shots just like on any digital compact camera.
Although many newer digital SLR's now have live view, the D60 does not so you cannot achieve what you want. All that the LCD is for is to view photos already taken and to provide camera menus and information in all other modes. Composing the images before pressing the shutter is done solely via the optical viewfinder.
May 07, 2010 | Nikon D60 Digital Camera
Mismatch between viewfinder and photograph
Is your camera an SLR, if so then your mirror might be at the wrong angle, if that is the case then you need to have a specialist tilt the mirror, if your camera is not a SLR then this is a common problem when taking pictures from a short distance away from your subject, as the view finder is above the lense so what appears centered in the view inder will be much higher up in the lense, there are two ways to fix this, one is to use the LCD, or most cameras have correction marks in the view finder,and these show where the actual edges of what the lense sees are, use the correction marks.
Jul 23, 2009 | Sony Alpha DSLR-A200K Digital Camera
My sony DSC-H1's LCD is not showing anything...but I can operate the camera with its view finder... Do you have any idea why it happens? and is there any master reset option for this camera?
I have a similar SONY camera. Turn the camera on and to the right of the viewfinder (or perhaps in a different location on your model) there will be a small button that reads, "FINDER/LCD". Press that button once to see if your view switches back from viewfinder mode to LCD display mode.
Jun 23, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
What is a Veiw Finder
It's where you find a view of what the light coming through the lens. Today's consumer camcorders place the viewfinder center-rear usually with a rubbery piece around the end as an eyepiece/cup. Many units shut off the image to the eyepiece if the flip-out LCD screen on the side is used.
Jan 15, 2009 | Sony Handycam CCD-TRV68 Camcorder
The view finder does not wotk
Try pulling out the eyepiece, it will reveal a switch that controls the focus, it maybe the problem, good luck
Aug 13, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
LCD not working
There's a good possibilty that your mode switch is broken. Same thing happened to my Z6. I was able to source replacement switches, and can replace them.
Jan 14, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Can't get image in viewfinder
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40x Digital Camera Logo
122 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
