Question about iLO DVDR05 DVD Recorder
Video but no audio r/o cables and tv how would I get it fixed
Not sure of your problem. You get video but no audio thru any of your inputs? Or is it just your tuner? Or your tv?
Posted on Jun 13, 2008
How to fix problem with TV that has no sound or picture?
Take it to a Samsung repair centre. It boards that need replacing, and there are many. You have to swap out the right ones.
Mar 28, 2017 | Televison & Video
MY PICTURE IS GREAT,BUT NO SOUND. WHAT CAN I DO TO FIX IT?
Make sure TV is not muted.Make sure the TV is not set to SAP (secondary audio protocol)Make sure TV input is correct (someone may have accidentally pressed the "aux" input button or similar causing the TV to use an input with no sound going to it)Make sure there is not a pair of headphones connected to the TV audio out jack on the side or front of your TV.Check all of the cables that are connected into the back of your TV. (it is possible the TV was moved slightly and a cable has become disconnected or loose)If you have a receiver or surround sound connected to your TV, turn it on and see if you get sound coming from the external speakers.Turn off the TV, cable box, and anything else connected to the TV. Sometimes turning everything off and then back on can fix the problem.If using an "S" video cable into an input on the back of your TV, these cables carry no sound, just video, so make sure you connect an audio cable too.Hook up an external device to the "TV audio out" input. This will be the test to see if it is a TV circuit board malfunction or the speakers are faulty in your TV.If you are connected to a satellite box, use the included remote and go into the "menu". Check to make sure sound settings are set correctly.
Read More: http://removeandreplace.com/2013/11/14/10-ways-fix-tv-picture-sound/#ixzz3lTeW6isH
Sep 11, 2015 | Televison & Video
No video for toshiba regza 55zv650u TV
Hello JAPP,
This failure is in the main board.,All the HDMI's are on the main board. If you can find a main board and DIY, then it might be cost effective to fix the TV.
Jun 08, 2017 | Televison & Video
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
Tv only accepts signal from the single black cable cannot get the tv to recognize the 2 audio cables and one video cable.. how do i fix this?
Hello
Your Emerson TVs audio format is not stereo; it is mono. Therefore only one audio input will be active. There is a Note give on your TVs manual. I copies it here for your information.
1. VIDEO (IN) jack- Connect to the video
output jack of a video camera or VCR.
2. AUDIO (INPUT) L/R jacks- Connect to
the left/right channel audio output jacks of
Note: The AUDIO (INPUT)L jack is for
mono input. The sound is heard from both
speakers. Use this jack for monaural audio
equipment to be hooked up.
OK.
Dec 21, 2010 | Emerson EWF2004 20" TV
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
DVD/CD Player with Video Cassette Recorder how do you connection to a old tv. The Old tv has no audio in or audio out for the Red, White & Yellow, audio/video cable.
The older TV's will normally only have inputs for co-ax cables labeled "antenna in" and "out to TV. In this case you will need to use those or get an audio/video converter. It has connections on it for S-video, the red white and yellow audio/video cables that you mentioned, as well as co-ax. Cost less than $20.00. That should fix your problem. Hope this helps you.
Oct 27, 2009 | Televison & Video
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Is there a way to hook up a HDMI connector to my WS-48413
Yes, there are several ways to hook up your HDMI to your TV but first, we need to understand that HDMI carries both audio and video signals though a single cable in digital form.
I am assuming you want to connect a device such as a digital cable box, Blu Ray or HD DVD player with an HDMI output to your TV. Since your TV has both digital (DVI) and analog (S-Video, component, etc) inputs, my suggestion would be to get and HDMI to DVI adapter (about $20 at buy.com) for your video and for your audio, use any RCA audio cable (I use the one from the Dollar Store). This would give you the best video resolution from your source device.
My next suggested solution would be to get an HDMI to component video + audio cable (< $10 at eBay for a 6' length) for a single-cable fix. Again component video carries analog signals so the DVI could be a better viewing experience but because the cost of the cables are minimal, I would try both solutions to see which fix would give you the better picture.
Note that since the audio is being run though RCA connectors in both instances, the digital Dolby, 5.1 or 7.1 surround sound tracks in high definition sources will not be reproduced if you connect your TV's audio-out to your audio receiver. To get the best audio, I would connect the HDMI device's digital out (optical, coaxial, etc) directly to the receiver.
Hope that helps. Have fun!
Aug 23, 2009 | Televison & Video
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
iLO DVDR05 DVD Recorder Logo
19 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
