Question about Necchi 4575 Mechanical Sewing Machine
Sears Kenmore 1168280 (Old machine not used much)
Sewing a pillow case and suddenly the needle won't move --- at all. With pliers broke needle, removed fabric. The large wheel which runs the needle etc. won't budge. The bobbin feature works. To engage this feature, have to unlock wheel. All that is fine. Just the needle won't move. Any ideas? Thanks. Lisa
  • Anonymous Mar 20, 2014
    needle moves fabric won't and have to use a lot of force to move it when sewing
  • Anonymous Mar 29, 2014
    I just got a used Kenmore 15008, could not move clutch wheel, motor straining and not moving it. Bobbin area is clear. Took it apart, clutch wheel off, bottom panel, and used liquid wrench on anything I could reach. Motor runs ok, without clutch engaged but needle does not go up and down unless I use a pliers on the rod inside the hand wheel, using a lot of force. It may have been seized up. Any suggestions or adjustments?
  • Necchi Master
  • 1,388 Answers
Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
Undo the needle clamp and remove the remains of the needle.
Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
Best Wishes
bargainbox.com.au
Posted on Jun 08, 2008
Needle **** screw is jammed
Perhaps your clamp screw is too tight. Remember, "lefty-loosy, righty-tighty". Take your pliers and turn left or take it to a repair-person.
Jul 02, 2012 | Singer Sewing Machines
My juki hzl35z will not pick up the bobbin thread suddenly! Help!
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Apr 26, 2012 | Juki HZL35Z Mechanical Sewing Machine
My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Apr 14, 2012 | Singer Sewing Machines
My kenmore is about 30yrs old .Never had a problem till now. I was sewing and stitched over a pin, broke needle,replaced needle. Now the problem is that the top thread bunches up underneath,also after i...
Sounds like the timing adjustment of the bobbin case has been upset. Have that checked, it involves an adjustment on the gear that drives the bobbin case.
Feb 22, 2011 | Kenmore Sewing Machines
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Can these needles be used with my sewing machine?
Don't know if this is helpful...but I have a very old Kenmore and 2 Brothers. I used the same needles with all 3 machines. No problems.
Apr 13, 2009 | Sewing Machines
Need new faceplate
you can actually smooth you needle plate you have with a emory board , a small file or sanpaper. Just smooth the jagged edge-quick and cheap
Mar 18, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
Needle Size.
I usually use Kenmore needles. I bought my machine through Sears and was told the needles were compatible. Otherwise I get the appropriate size for my fabric weight at JoAnn Fabric. As long as it has a flat back it will work fine.
Jun 28, 2008 | Janome 2049LX Mechanical Sewing Machine
Fabric not feeding and jamming occurs
When this happens it is because the thread tension was not right so it gets stuck under the bobbin case and the feed dogs. Use a bigger lint brush and take out the bobbin casing and clean out the shuttle. When you rethread pull slightly on the thread before you feed it through the needle. This will make sure the thread is properly in the tension discs.
Jun 13, 2006 | Kenmore 19233 Computerized Sewing Machine
Necchi 4575 Mechanical Sewing Machine Logo
289 people viewed this question
Top Necchi Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
