Hi, First of all make sure, all connection in properly connected. Then go to Start>Control Panel> Add Hardware > Then it will search for hardware & new drive will display on my computer. If problem continues make sure you have already made partitions for hard drive if you not credited it make partition of hard drive it will work fine i am sure.
remove CMOS battery and the harddisk, then start ur system. It will shows the msg plz insert the boot device. Now connect the CMOS and harddisk. You will get the display...
The weak airflow from the power supply unit (PSU) is suspect. Virus / Malware scanning is a disk and processor intensive operation - resulting in greater load on both. Increased load translates to heat. Check to be sure that the processor (CPU) fan is running, too. An overheating PSU and CPU can cause all types of problems.
Are you using a genuine XP install disk/image or a disk of questionable origin? Use of bogus OS disks is "asking for trouble".
If your system BIOS or set up (accessed during boot) allows, try to located the page that displays component temperatures and fan speeds. Check this immediately after rebooting from a an unplanned shut down - if unable to locate this set up page, download HWMonitor at:
http://www.cpuid.com/hwmonitor.php
It is a free program - choose the 32 or 64 bit version. Note fan RPM and CPU core temps to help determine where heat is coming from - or which fans aren't operating correctly.
When you power up the computer press F1 ore F2 or "del" key toenter in bios then check your hardisk is detected or not. If not then if you have desktop open cpu cabinet then reconnect power cable and ide or sata cable to harddisk also check your harddisk is set to master.
First check your num lock led if it on and off when you press num lock key then your cpu is ok. Then therer is issue with monitor to cpu loose connection or Screen resolution problem. For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok. Aslo reconnect connection from monitor to cpu vga port. Also check in bios some times your harddisk is not detected proeprly. If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk. Refix RAM memory. Pull cmos cell for 15 minutes then check. Thanks for using fixya. Pls rate solution if it help you .
I do not recommend removing Vista completely,if that is what your laptop/PC came with, as most components and drivers installed will be Vista specific. If you need to have XP, make sure you have all the drivers for XP first.
Open tools menu, on top bar of your folder, and chose option 'folder options'. Alternatively open 'folder options' from control panel. In 'folder options' box use view files option. In view files chose display hidden files and display system file. Here is the way to do this in detail
To change attributes click right button of mouse on folder, chose properies, at the bottom of properties box you have the attributes.
MY PACKARD BELL PIV HAS N1996 MOTHER BOARD I cant see any display on my screen when i turn on my computer. But it looks it has read all the information from harddisk and loaded the operating system. but on screen i cant see any raster i.e. display.
First At this time u observe one thing check the Numlock Status if it is ON/OFF (Glow ) in Keyboard when u pressing the Numlock key, the system is giving display check with pci vga card.
If not u remove the Ram module and heard the Beepsound,if Beep is comming Clean the Ram & Ram slot the try it again If not check with another Ram module.
If it is also not problem u clear the CMOS once and check it
