Question about Brother IntelliFAX 2800 Laser Fax
Receiving Faxes I have a Brother Intellifax 2800 and a panasonic phone. The fax machine is set to receive faxes after 2 rings and the phone should answer after 4. Just recently the fax machine stopped receiving faxes, but it still sends. The fax machine won't receove even when set to Fax only. Anyone know what could be the problem?
  • Anonymous Dec 04, 2008
    I can send out faxes with no problem But I am not able to receive any . the phone rings but I can seem to get nothing.
    Scholar:
  • 159 Answers
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Posted on Jun 09, 2008
Phone rings- not receiving faxes- unit copies- paper feeds fine- new toner and roller installed.
try changing the amount of time the fax machine rings before it answers to a low number... if that doesn't work try a reset... info on this page...
Dec 17, 2009 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Fax machine not receiving faxes
First pick up the handset and make sure you have a dial tone on the line.Second thing to check is to make sure that your fax machine set to "FAX" mode,not"PHONE"mode, and it is in auto receive,not manual receive mode.
Sep 09, 2009 | Brother IntelliFAX 2800 Laser Fax
I have a Brother Intellifax 2800 and it can send faxes but just rings and rings and won't receive them.
what does the display read. If you want the fax to auto answer. the display needs to read ( fax only). to chang this setting if not reading that massage press the receive mode button till fax only is in the display
Jan 30, 2009 | Brother IntelliFAX 2800 Laser Fax
BROTHER FAX-560 THAT IS NOT WORKING TO FAX OR RECEIVE
Look in the manual for setting up receiving faxes. There is a default number of rings setting that will make your machine capture the phone line after a specified number of rings.
Jan 07, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Not receiving any faxes.
line not workimg,and put fax mode and checkreceiving kbps 1500
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
Receive faxes
Scroll through the menus.
You need to set your machine to AUTO MAGNIFICATION or AUTO REDUCTION
Oct 28, 2008 | Brother IntelliFAX 2800 Laser Fax
Setup
Yes, just set the receive mode to "manual" the machine will then just ring when a fax is incoming and not print. It may become annoying after a while because the sending machine will try to send numerous times. You can get around this by setting the ring volume to mute.
Jun 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Can fax but can't recieve
your machine may be in mannual mode or in answering machine mode. First confirm weather your machine is in auto/fax mode for receiveing.put the machine in to fax mode with sigle ring pattern.
May 02, 2008 | Brother IntelliFAX 2800 Laser Fax
Brothers 2800
The machine is probably set to "manual receive." Check the receive mode. In "Manual" mode the machine will ring until the start" button is pressed. Fax mode will allow the machine to receive faxes as will the "Auto" mode which will allow both faxes and telephone calls automatically.
Jan 03, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
201 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
