Question about Compaq Evo N410C Notebook
Wont boot up to Windows
Says stop error and if this is the first time you seen this error, shut it down and restart computer. Then it refers you to owners manual which we do not have. So I do not know what to do. I was wondering if you could offer some assistance.
    Genius:
  • 1,601 Answers
If it is a blue screen, Then you have a bad driver or new hardware installation. Try to start in safe mode and uninstall..
Posted on Jun 08, 2008
How to stop Windows 10 from automatically restarting after idle for around 5-15 minutes.
The kernel power event ID 41 error occurs when the computer is shut down, or it restarts unexpectedly. When a computer that is running Windows starts, a check is performed to determine whether the computer was shut down cleanly. If the computer was not shut down cleanly, a Kernel Power Event 41 message is generated.
Before we proceed with the troubleshooting steps, please answer the questions given below.
a)Do you remember making any changes prior to this issue?
b)Did you check if all the drivers are up to date?
Let us follow the methods given below.
Method 1: Run System maintenance troubleshooter.
Follow these steps:
a) Press Windows key + W on the keyboard
b) Type Troubleshooter then click on Settings under the Search field
c) In Settings click on Find and Fix Problems
d) Click on System and security
e) Click System maintenance follow the prompts from there.
Method 2: Try booting the computer in safe mode and perform a clean boot.
Step 1: Perform Safe Mode
Click the link and follow the steps "Windows Startup Settings (including safe mode)"
http://windows.microsoft.com/en-US/windows-8/windows-startup-settings-including-safe-mode
Check if you face the same issue in safe mode. If the issue doesn't persists in safe mode, the place the computer in clean boot and check.
Step 2: Perform Clean Boot.
To help troubleshoot error messages and other issues, you can start Windows 8 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
Important: Reset the computer to start as usual.
Note: After you have finished troubleshooting, follow these steps to boot to normal startup.
a) Press the 'Windows + R' key on the keyboard.
b) In the 'Run' windows type 'MSCONFIG' and click 'Ok'.
c) On the 'General' tab, click the 'Normal Startup' option, and then click 'OK'.
d) When you are prompted to restart the computer, click 'Restart'.
If the issue persists, I would suggest you to perform a system restore and check if it helps.
Method 3: Perform a system restore.
Refer to the link given below and follow the instructions for system restore.
How to restore, refresh, or reset your PC
http://windows.microsoft.com/en-US/windows-8/restore-refresh-reset-pc
Also refer to the article given below.
Windows Kernel event ID 41 error "The system has rebooted without cleanly shutting down first" in Windows 8, Windows Server 2012, Windows 7, or Windows Server 2008 R2
http://support.microsoft.com/kb/2028504
hope this helps
Jan 13, 2016 | Computers & Internet
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
"A problem was detected and
Re boot in safe mode if normal boot is not possible and run CHKDSK/F
DO NOT DISABLE ANTIVIRUS!!!!!!
That should sort hard disc errors out then download iobit.com and run the registry utility, that will remove more errors. It is a free ware programme and works very well.
Hope that sorts it out for you.
Feb 26, 2011 | Computers & Internet
Windows vista on my laptop did not boot that happend when i was made some windows updates so i try to set up another windows xp from a new bootable cd ,the windows begain to set up but its shut down and a...
I had a similar problem but I can't recall if it was the same error number as in your message---what I did was used the recovery console and re-wrote my master boot record (MBR) my error was in the MBR causing my computer not to boot up in the first place. Your bootable cd should give you an option to use the recovery console before you reinstall, take it and use "fixmbr" at your dos prompt. XP works like that, but I've never had that problem with vista yet....it's worth a try if vista does the same.
Feb 14, 2011 | Computers & Internet
The problem I'm experience with my computer start when a blue sceen appears. The statement states: A problem has been dected and windows has been shut down to prevent damage to my computer. If this...
If you are running Windows XP, the boot to the XP CD, press R when prompted to access the Recovery Console, then run the command CHKDSK /R at the C:\windows\system32\ prompt
If you get indications of recovering lost allocation units, then the disk surface of the HDD is likely bad and the HDD will need to be replaced.
If running Windows Vista or Windows 7, boot to the Windows DVD and select REPAIR MY COMPUTER
Dec 23, 2010 | Dell Computers & Internet
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
My computer wont load windows a problem has been detected and windows has been shut down to prevent damage to your computer. unmountable boot volume if this is the first time you seen this stop error...
Your Operating System probably corrupted due to unexpected power failure or any other reason. You may have to setup widows again.
Before reinstallation take backup of all necessary file in a separate Hard Disk from your (C: ) Drive , existing desktop , my documents , share folder, etc. to do this you have to connect you Hard Disk with another workable PC.
After taking all necessary backup, setup Windows freshly and it is recommended to format C drive during fresh setup.
Jul 12, 2009 | Averatec Laptop Keyboard for 3200 Series
Hp compaq presario v3000 is not loding the OS, show an error
  • as you boot the computer, start tapping the F8 keys
  • From the boot menu, select Safe Mode
If this seems to work, you can try restoring the computer to an earlier point from Start > All Programs > Accessories > System Tools > System Restore.
If Safe Mode also fails to load, you would have to check your disk for errors or you may have to install XP all over again.
Please get back, if you need any further help.
Jan 09, 2009 | HP Compaq Presario SR1920NX PC Desktop
Error screen
what was the last thing you installed? or pluged into the computer?
when windows starts to boot press f8 to go into safe mode and see if you can remove the last thing you installed.
Jan 08, 2008 | Toshiba Satellite A105-s4184 Notebook
Compaq Evo N410C Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
