Dvd Is there a way you can put a dvd in a tv/dvd combo, but not see it in that tv because its too small. And connect that tv/dvd to a bigger size tv. Its the only dvd that works.
    Sergeant:
  • 291 Answers
Pinkky25;;
yES & NO !!
U can buy a DVD\VHS player\recorder for half the price of what you want to do. If you don't have the knowledge & hadware[extra dvd, parts, etc,etc] it will be VERRY!!...VERRY!! (you will notice that I spellyed VERY with two RR HARD. It could be done, but not econimical!!
Posted on Jun 09, 2008
Can I connect a small TV with built in Dvd player to a second bigger TV to watch a Dvd on bigger TV??
If the small set has audio and video outputs that can be plugged into the audio/video inputs of the larger set, then yes! If no outputs, you are out of luck!
Mar 20, 2015 | Televison & Video
TV picture is smaller than screen, how do I make it bigger?
See if there is a "wide" button on the remote. Should scroll through the display size options
Go to menu and picture adjustments are there as well
Mar 20, 2014 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
Dvd won't eject from tv/dvd combo stuck
Try looking for a small hole where the DVD goes in the TV about the size of a paper clip. Some of the times like on a computer there is a small hole that you can put a paperclip in and push on an internal button and this will release the DVD.
Jan 06, 2014 | Proscan Televison & Video
DVD stuck in tv combo player
There should be a very small hole or opening on or near the DVD drawer. Straighten a small paper clip to insert in the hole. It should trip the drawer open.
Dec 15, 2013 | RCA 26LA30RQD 26 LCD TVDVD Combo
RCA D52W136D 52 in. TV/DVD Combo dvd does not play
did you try to get a dvd cleaner to clean out your dvd player.
Feb 13, 2010 | RCA D52W136D 52 in. TV/DVD Combo
I have a samsung dvd vcr combo connected to a jvc tv but when i have press play i get no screen for either video or dvd the dvd runs but no recpetion
If you are connecting the dvd/vcr combo to the tv with coax cable first make sure the tv is on channel 3 and also make sure you have the samsung dvd/vcr combo on channel 3 by using the remote that came with the samsung. You should get picture and sound then if not try channel 4 on tv instead of channel 3. If that doesn't work try to put the samsung on channel 4 as a last option to try. This is only recommended if the combo is hooked to tv with coax cable out of combo to in on tv. Make sure coax is plugged into the out jack on combo and in on tv.
Nov 26, 2008 | Insignia Digital-to-Analog Converter for...
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Connecting dvd/vcr combo with tv and digital cable box.
You trying to put the DVD/VCR combo between the cable box and the TV? OK, cable out goes to vcr in, vcr out goes to tv, I think you got that. Now there should be a tv/vcr button on the vcr/dvd, you need to press that when the unit is on. Also, make sure you are on the correct input on both the vcr and the tv, usually video 1 or AUX and choose line in or L1 on the vcr/dvd. If the tv/vcr button is toggled, itll completely bypass the vcr/dvd player.
Mar 03, 2008 | Toshiba 32A41 32" TV
Stuck DVD
I have a Mintek DTV-265-D which is frozen and neither the buttons on the set nor remote will work. Anyone know how it get it working?
Sep 02, 2007 | Mintek DTV-233 23 in. TV/DVD Combo
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
