Question about Gateway MX3215 Notebook
MX3215 Gateway Notebook
My power jack is loose. Does Gateway make a docking station like dell or hp that can give my laptop power?
Send it in to gateway, they will replace it, mine did the same thing and broke to the point where the computer would power on until after the gateway screen and then a blue screen would show up. basically the computer was turning itself off so no damage to the system would occur. i got it fixed and then a few months later, the lcd just stopped working. so i went out and bought a dell inspiron 1525. i dont know what to do if ur lcd stops working.
Posted on Jul 05, 2008
    Genius:
  • 1,601 Answers
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Is there a docking station for my mt6840 gateway computer?
I do not believe there is a docking station for that model. But... Try pulling out the battery. Then plug in the power supply and see if you can get it to power on. If so wiggle the plug and see if it shuts off. If either if those are true, en you most likely need your DC Jack replaced. You would want to take it to a laptop repair shop. It is usually $20 for the part and around 1.5 - 2 hours labor for the repair. Requires pulling out the motherboard and desoldering the old jack. And soldering in a new one. No fun
Dec 12, 2011 | Gateway MT6840 Notebook
Dc jack is not working, can I still use a docking
I have seen this problem with many laptops.
What has happened is that the power connector on the laptop has loose solder connections and will not trasfer the power through the jack. Either the jack needs to be resoldered on the motherboard or replaced. This is a very intense repair, because the motherboard has to be removed for the repair.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Mar 15, 2010 | HP Compaq Presario V2000 Notebook
Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
Aug 10, 2009 | Dell Latitude D610 Notebook
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
Not charging off the power jack
One wrong spark and you'll need a new laptop. Take it to a reputable repair person. A jack is an repair.
Mar 29, 2009 | Dell Inspiron 600M Notebook
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Plug in power cord and push power button, nothing comes on
Yup Yup I had the 28, same problem, the issue is within the adapter plug itself, I ended up taking my laptop apart and hard wiring the the connections directly into the wires that came off the plug, it was the only way to solve the issue without ordering the part from gateway,,,this is a image of the device that is causing you this misery.
t
http://cgi.ebay.com/DC-Power-Jack-For-Gateway-MX3212-MX3215-MX3225-MX3228_W0QQitemZ330288544158QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item330288544158&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
Nov 21, 2008 | Gateway MX3215 Notebook
AC Adaptor Problem
no u can buy the power plug for it u have to take it all aprt tho like mobo out then un solder the ac jack install new one from ebay 4 bucks ok
Jan 21, 2008 | Dell Inspiron 6000 Notebook
Gateway MX3215 Notebook Logo
214 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
