Question about Sony Cybershot S650 Digital Camera
Camrea wont turn on
Go to turn carmea on it wont green light comes on for a couple of seconds new battiers have been put in the problem still remains
  • Anonymous Jul 04, 2008
    My camera wont turn on anymore. I turn it on and it goes on for 2 seconds and then switches off.
  • Anonymous Jul 16, 2008
    hi, i was given a sony digital camera dsc-s650 as a gift whilst visiting america in octber 2007, i have been using my camera regularly till the 12th july 2008. i put in new batteries on sunday and since then the camera comes on for less than a second. have tested the batteries with an amp meter and also inside the battery compartment in the camera, there is definate power to the camera but it won't switch on. please can you help me. many thanks kathy powell - heidelberg western cape
  • 10,594 Answers
Lens is jamed in ur camera thats why it shut the power.
Posted on Jun 09, 2008
Snx 32gt1 internet tv wont come on
Probably a failing power supply
Jan 14, 2017 | Sony Televison & Video
MY R2D2 INTERACTIVE ASTROMECH DROID WONT MOVE OR DO ANYTHING
On the front of the droid there is a red button that lights up when turned on & turns off after a couple of seconds, depress that button to free up the droid. Its called the wheel lock control button. That should free up your R2
Apr 15, 2012 | Hasbro Star Wars R2 D2 Interactive...
Wii has no power whatsoever going in
The button has to be pressed until you see the light come on try using the wimote power button on the upper left corner hold it until you see the light if its yellow its in standby if its green its on you should see the disk entry area turn blue a sec when it comes on. Then it should be green on the power light if no lights in just a couple or 3 seconds holding it down you may have 2 bad wii's in a row. If you take it back ask them if they have a test model on the floor and tell them to show you exactly how it works to power on and off.
Dec 02, 2011 | Nintendo Wii Console
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Couple seconds after i turn my camera on, green
This was also an issue with my own camera and I was getting really really mad that it SHOULD have been working, but wasn't. I fixed the issue by removing the batter and taking a very very very small screwdriver and prying the contacts back just a little bit in order to make contact with the battery. I placed the batter back in and voila! Hope it works with you!
Nov 14, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Hi my D90 viewfinder problems
I believe what you want to do is drop the unit from the same height but on the opposite side. This will equalize the damagednessotometer rating on your cameras bios drop detector settings review for imfullofshit sectors 123 &445.
Sep 24, 2009 | Nikon DSLR D90 Digital Camera
My carmea wont download without cd
try cassete tape to download
Sep 21, 2009 | Cameras
Have problem with my control
to see if your remote is working obvouisly put in new fresh batteries turn on the camrea on your phone or get a digital camrea and point the infa-red sensor at the camrea and press some buttons while looking at the screen of your phone/digi cam should see a white flashing lights as you press the button if nothing then the control is dead
Sep 10, 2009 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Mar 30, 2009 | Samsung L100 Digital Camera
Sony Cybershot S650 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
