Question about Phoenix Gold PD-MOTOR7 Car Video Player
New new cables and monitor
Can you tell me where on earth i can purchase these items
    Problem Solver:
  • 5 Answers
IN A **** SHOP AT 15 N CALIFORNIA IN CHI
Posted on Jun 08, 2008
How to connect the HDMI Cable from monitor to Computer which has no HDMI ports?
You need a purchase a new cable. I assume your HP pavilion is under 5 years old. And you should have a white DVI port in the back for a monitor. If you do have that connector, then all you need is a DVI - HDMI cable, make sure the DVI will be to the computers end and HDMI to the monitor.
for example this cable:
http://www.amazon.com/AmazonBasics-HDMI-Adapter-Cable-Meters/dp/B001TH7T2U
Dec 31, 2013 | HP Pavilion Computers & Internet
My monitor cable has a broken wire can i get a new monitor cable my monitor model is... MD 30917 pn
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Jul 14, 2011 | Medion Computers & Internet
I purchased a 3M 15"
This display uses a capacitive touchscreen. It relies on the conductivity of your finder work. It may be that it has lost sensitivity and only works when there is a path to ground through your body. If this is the case then the touchscreen will need replacing.
Feb 18, 2011 | 3M 11-4922-129-00 (Black) 15 in. Flat...
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
Ive just purchased a new windows 7 pc and i cant install my aoc monitor software, it hangs and nothing happens. i have java and the latest flashplayer
Why on earth would you want to install any MONITOR software??? What do you need it for??? Let Windows configure your monitor as Plug and Play, and then in desktop properties set the resolution you want.
Aug 08, 2010 | Computers & Internet
I have two pyramid MV7SC 7.2 in. car monitors. I need information on how to purchase two cable wire that contains the ground, video out,video in, audio in,and volt. (known as the connection wire)
go to say Radio Shack and purchace some Multi cored, (4 -6 core) Co-axial cable, this means you have 4 - 6 "Conductors" and use the shield for all the earths & negative power,. This will give you what you need. At a pinch, you could always get a single core, audio coax, and run 4 of them and tape, or zippy tie, into a bundle.
Feb 23, 2010 | Pyramid MV7SC 7.2 in. Car Monitor
While working on PC der was spark at plug point and now monitor is not turning on.
u need to either change the power cable of the monitor or go for a repair of the LCD.
the power cable may have been spoilt most probably,use earthed sockets for ur PC and check lose connections.
i myself had experienced this problem earlier due to improper earthing
Jan 13, 2010 | Acer AL1716 17" LCD Monitor
Following the purchase of a new home I want to install a new light in one room. The new light fitting has the basic connection terminals for Active, neutral and earth. The existing light on the ceiling has...
please remember to turn the power off when you are doing this. the extra cable is probably a looped or joined cable. put it in a connector or solder it with tape and leave it behind the light fitting or in the terminal block. connect the same cables up in the active, neutral and earth. like for like. make certain the power is off when you do this.
Sep 25, 2009 | Electrical Supplies
Can you get replacement vga cable for compaq fp5315
VGA cables (15pin DSub) are a standard item, you can purchase them on the Internet or your friendly computer shop.
Sep 15, 2009 | HP Compaq FP5315 15" LCD Monitor
Phoenix Gold PD-MOTOR7 Car Video Player Logo
35 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Mark Skinner
hoyzee1
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
